You can in GUI set Compression=> None/Enable/Adaptive. comp-lzo yes = ENABLED
Thanks,
I don't get any option for "comp-lzo yes = ENABLED", when using enabled or adaptive, I've added the "comp-lzo" command to the custom config.
If I enable the vpn client\ compression setting to enabled or adaptive I get an error "connecting ip/routing conflict" message uner the VPN status tab.
This im unsure about but try set (rcvbuf 0) in custom config.
Is this just a case of adding "rcvbuf 0" as a line to the custom config?
After a few other tweaks I now get 20mbps D/L with this clean log...
Mar 20 13:28:11 rc_service: ntp 662:notify_rc restart_upnp
Mar 20 13:28:11 rc_service: waitting "start_vpnclient1" via ...
Mar 20 13:28:13 pppd[491]: System time change detected.
Mar 20 13:28:14 rc_service: zcip 770:notify_rc start_firewall
Mar 20 13:28:14 rc_service: waitting "start_vpnclient1" via ...
Mar 20 13:28:17 kernel: tun: Universal TUN/TAP device driver, 1.6
Mar 20 13:28:17 kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Mar 20 13:28:18 openvpn[781]: OpenVPN 2.3.8 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Dec 24 2015
Mar 20 13:28:18 openvpn[781]: library versions: OpenSSL 1.0.2e 3 Dec 2015, LZO 2.08
Mar 20 13:28:18 openvpn[782]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mar 20 13:28:18 openvpn[782]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Mar 20 13:28:18 openvpn[782]: UDPv4 link local: [undef]
Mar 20 13:28:18 openvpn[782]: UDPv4 link remote: [AF_INET]81.171.75.11:1194
Mar 20 13:28:18 openvpn[782]: TLS: Initial packet from [AF_INET]81.171.75.11:1194, sid=ab2818ec 78ffd15a
Mar 20 13:28:18 openvpn[782]: VERIFY OK: depth=1, C=US, ST=VPN, L=VPN, O=VPN, OU=VPN, CN=VPN, name=VPN, emailAddress=VPN
Mar 20 13:28:18 openvpn[782]: Validating certificate key usage
Mar 20 13:28:18 openvpn[782]: ++ Certificate has key usage 00a0, expects 00a0
Mar 20 13:28:18 openvpn[782]: VERIFY KU OK
Mar 20 13:28:18 openvpn[782]: Validating certificate extended key usage
Mar 20 13:28:18 openvpn[782]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Mar 20 13:28:18 openvpn[782]: VERIFY EKU OK
Mar 20 13:28:18 openvpn[782]: VERIFY OK: depth=0, C=US, ST=VPN, L=VPN, O=VPN, OU=VPN, CN=vpn, name=VPN
Mar 20 13:28:18 miniupnpd[664]: shutting down MiniUPnPd
Mar 20 13:28:19 dnsmasq[424]: read /etc/hosts - 5 addresses
Mar 20 13:28:19 dnsmasq[424]: read /etc/hosts.dnsmasq - 11 addresses
Mar 20 13:28:19 dnsmasq-dhcp[424]: read /etc/ethers - 14 addresses
Mar 20 13:28:19 dnsmasq[424]: using nameserver 31.55.186.78#53
Mar 20 13:28:19 dnsmasq[424]: using nameserver 31.55.185.46#53
Mar 20 13:28:19 zcip client: configured 169.254.113.188
Mar 20 13:28:19 miniupnpd[789]: HTTP listening on port 45728
Mar 20 13:28:19 miniupnpd[789]: Listening for NAT-PMP/PCP traffic on port 5351
Mar 20 13:28:19 rc_service: ntp 662:notify_rc restart_diskmon
Mar 20 13:28:19 rc_service: waitting "start_firewall" via zcip ...
Mar 20 13:28:20 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Mar 20 13:28:20 openvpn[782]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mar 20 13:28:20 openvpn[782]: Data Channel Encrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Mar 20 13:28:20 openvpn[782]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mar 20 13:28:20 openvpn[782]: Data Channel Decrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Mar 20 13:28:20 openvpn[782]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Mar 20 13:28:20 openvpn[782]: [vpn] Peer Connection Initiated with [AF_INET]81.171.75.11:1194
Mar 20 13:28:21 dnsmasq-dhcp[424]: DHCPREQUEST(br0) 192.168.1.218 1c:5c:f2:40:fa:a8
Mar 20 13:28:21 dnsmasq-dhcp[424]: DHCPACK(br0) 192.168.1.218 1c:5c:f2:40:fa:a8 Howells-iPhone
Mar 20 13:28:21 disk_monitor: Finish
Mar 20 13:28:22 openvpn[782]: SENT CONTROL [vpn]: 'PUSH_REQUEST' (status=1)
Mar 20 13:28:22 openvpn[782]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 198.18.0.1,dhcp-option DNS 198.18.0.2,rcvbuf 262144,explicit-exit-notify 5,route-gateway 172.21.94.1,topology subnet,ping 20,ping-restart 40,ifconfig 172.21.94.4 255.255.254.0'
Mar 20 13:28:22 openvpn[782]: OPTIONS IMPORT: timers and/or timeouts modified
Mar 20 13:28:22 openvpn[782]: OPTIONS IMPORT: explicit notify parm(s) modified
Mar 20 13:28:22 openvpn[782]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Mar 20 13:28:22 openvpn[782]: Socket Buffers: R=[131072->245760] S=[131072->131072]
Mar 20 13:28:22 openvpn[782]: OPTIONS IMPORT: --ifconfig/up options modified
Mar 20 13:28:22 openvpn[782]: OPTIONS IMPORT: route options modified
Mar 20 13:28:22 openvpn[782]: OPTIONS IMPORT: route-related options modified
Mar 20 13:28:22 openvpn[782]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mar 20 13:28:22 openvpn[782]: TUN/TAP device tun11 opened
Mar 20 13:28:22 openvpn[782]: TUN/TAP TX queue length set to 100
Mar 20 13:28:22 openvpn[782]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mar 20 13:28:22 openvpn[782]: /usr/sbin/ip link set dev tun11 up mtu 1500
Mar 20 13:28:22 openvpn[782]: /usr/sbin/ip addr add dev tun11 172.21.94.4/23 broadcast 172.21.95.255
Mar 20 13:28:22 openvpn[782]: updown.sh tun11 1500 1570 172.21.94.4 255.255.254.0 init
Mar 20 13:28:24 disk monitor: be idle
Mar 20 13:28:24 rc_service: service 848:notify_rc updateresolv
Mar 20 13:28:24 dnsmasq[424]: exiting on receipt of SIGTERM
Mar 20 13:28:24 dnsmasq[854]: started, version 2.76-g41a8d9e cachesize 1500
Mar 20 13:28:24 dnsmasq[854]: warning: interface ppp1* does not currently exist
Mar 20 13:28:24 dnsmasq[854]: asynchronous logging enabled, queue limit is 5 messages
Mar 20 13:28:24 dnsmasq-dhcp[854]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Mar 20 13:28:24 dnsmasq[854]: read /etc/hosts - 5 addresses
Mar 20 13:28:24 dnsmasq[854]: read /etc/hosts.dnsmasq - 11 addresses
Mar 20 13:28:24 dnsmasq-dhcp[854]: read /etc/ethers - 14 addresses
Mar 20 13:28:24 dnsmasq[854]: using nameserver 198.18.0.1#53
Mar 20 13:28:24 dnsmasq[854]: using nameserver 198.18.0.2#53
Mar 20 13:28:24 dnsmasq[854]: using nameserver 31.55.186.78#53
Mar 20 13:28:24 dnsmasq[854]: using nameserver 31.55.185.46#53
Mar 20 13:28:27 openvpn[782]: /usr/sbin/ip route add 81.171.75.11/32 via 172.16.13.7
Mar 20 13:28:27 openvpn[782]: /usr/sbin/ip route add 0.0.0.0/1 via 172.21.94.1
Mar 20 13:28:27 openvpn[782]: /usr/sbin/ip route add 128.0.0.0/1 via 172.21.94.1
Mar 20 13:28:27 openvpn-routing: Configuring policy rules for client 1
Mar 20 13:28:27 openvpn-routing: Creating VPN routing table
Mar 20 13:28:27 openvpn-routing: Removing route for 0.0.0.0/1 to tun11 from routing tables
Mar 20 13:28:27 openvpn-routing: Removing route for 128.0.0.0/1 to tun11 from routing tables
Mar 20 13:28:27 openvpn-routing: Added 192.168.1.1 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:27 openvpn-routing: Added 192.168.1.2 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:27 openvpn-routing: Added 192.168.1.204 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:27 openvpn-routing: Added 192.168.1.56 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:27 openvpn-routing: Added 192.168.1.73 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.133 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.191 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.205 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.211 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.250 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.12 to 0.0.0.0 through WAN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.121 to 0.0.0.0 through VPN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.122 to 0.0.0.0 through VPN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.123 to 0.0.0.0 through VPN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.124 to 0.0.0.0 through VPN to routing policy
Mar 20 13:28:28 openvpn-routing: Added 192.168.1.218 to 0.0.0.0 through VPN to routing policy
Mar 20 13:28:28 openvpn-routing: Completed routing policy configuration
Mar 20 13:28:28 openvpn[782]: Initialization Sequence Completed
