I have the Asus RT-AC66R for almost 6 months now it works great. But the problem I have is the re-connection. I am using the charter cable internet, last night I disconnect the cable modem to test something, but once I re-connect my AC66R to the power, trying to get internet connection. It will not work. I think it took me like an hour to get the signal back. All the lights from my model looks normal. For some reason the router not receiving signal at all.
From the admin page, I don't see any green computer icon on the upper right which lights up when it is connected. The internet status only showing disconnected.
I also noticed the lease time and lease expires only shows "renewing" something like that. But it look like an hour i gain my connection back.
Is this a known issue for this router? From my old Linksys and netgear, never happened like that, I mostly get signal immediately.
I am using the firmware 3.0.0.4.374_979
I unplugged the router, cable modem like tons of time, re-connect, disconnect wait for minutes , reconnect, Nothing happen. So basically it will work but it takes super long time.
Hope someone can help me out here.
