strange connection issues
one other thing i do not understand is, on my network map>connected clients> wired list, i can see a fifth connection (i did post about this recently and i was suggested this is a bug in the software and it could be a previously connected device) well, since then, i have discovered what this connected device is...
My internet connection is a WDSL....i have a MikroTic device on my roof receiving signal from ISP and the cable coming from MikroTic goes into WAN port (blue) but i do not remember this showing up on my network map>connected clients> wired list before! why it shows up now i have no idea...
One thing i noticed after things got back to normal, is that above mentioned "fifth" connection in my network map>connected clients> wired list is no longer there!
My $0.02...
Diversion does work but only updates its number of blocked DNS sites twice a day.
Use Dual Band SmartConnect, auto channel for both bands, 2.4 GHz on 20 MHz and 5 GHz on 80 MHz. Don't use DFS channels.
Network Map has always been wonky. It may take a day or so to show connected clients. Then again it may never show them.
Use a flitering DNS resolver such as Quad9 or Cloudflare Security (1.1.1.2 and 1.0.0.2)
I feel the Asus firmware works better for my environment. Sure, I have tested Merlin (this past weekend in fact) but have gone back to stock Asus. I do not push 160 MHz on the 5 GHz band but use 80 MHz for better range and stability. Also use WPA2-Personal as I have several old clients that do not like WPA2/WPA3-Personal. To block adds I use a RPI3b+ with Pi-Hole 6.
This advice is not good for regions with large power differences on 2.4GHz and 5GHz band. In Europe 2.4GHz band is restricted to 100mW, 5GHz band non-DFS to 200mW and 5GHz band in DFS allows up to 1000mW on selected channels. Smart Connect - forget about it. Your experience in the US with up to 1000mW on both bands is totally different. Your router is technically different to begin with.
