Asus RT-AC66U Merge VLans
Tenza
Hi, I would like to know how I can trunk the VLANs 101 and 105 to the Port 4 on my Asus RT-AC66U the same way this Cisco E4200 running Tomato is doing:
I have 101 with VOIP and 105 with IPTV. Currently my Asus has the stock firmware, is there a way to do this on the stock firmware? If not, can Merlin do this?
The port 4 will connect to the WAN port of another router that will manage the TV Box and Phone.
Thank you!
Perhaps with the "brctl" or "vconfig" commands? Maybe even the "wl" command?
There is a thread where some fellow figured out how to manually control vlan tagging. He even showed how to avoid a few firmware bugs to achieve proper configuration. I would try to find it but I need sleep. :)
There is no GUI method. Command line only (afaik).
Hey Nullity, when you have the time could you please find that thread? I'm new to Merlin, and it would probably help me a lot. Thanks!
