Asus RT-AC66U not port forwarding
mcnylen
Hi. I have now spent several hours trying to get my DirecTv GenieGO to work from the outside. I have tested the recommended ports 8082:8083, 8084:8085 and 8086:8087 with zero luck. The GenieGO has a static IP address and I have put the range(s) under port range leaving the local port blank. I have tried every single combination TCP and Both. Firmware on the ASUS is, supposedly, the latest 3.0.0.4.376_3861-g11c21b3.
What is interesting is that i go to canyouseeme.org and I cannot even get to Port 80. I have disabled the Firewall. I have tried using a MAC and my Android Smartphone as well to no avail. Any ideas - this is very frustrating and of course DirecTV takes zero responsibility.
Best,
M
Best,
M
Local port are the numbers you've just listed. You need local port or router can't redirect it.
Best,
M
Finally got it to work. It was the Comcast Modem that was the issue. I got it to Port Forward and the DirecTV Gizmo works now, for now anyhow.
