Thanks to this forum which I’ve been lurking on, I’ve manage to solve an issue I’ve been having on my RT-AC66U.
ISSUE:
Connection speed (not signal) would degrade after 2-3 days to N speeds or slower.
SOLUTION:
Installed Merlin’s latest firmware.
The above issue took me a few weeks to realize I had performance issues in the first place. I noticed I had to reboot my router regularly to get 1-1.3Gbps connection speed. When I realized this wasn't OK or normal after reading the forums, I started serious debug of the issue.
The first thing I noticed was that I wasn't seeing other 5GHz wireless traffic interrupting my connection nor do I have a 5GHz phone in my house (not sure about neighbors). My signal strength varied between -38db and -42 but the connection speed would go from 1-1.3Gpbs on day 1 to as low as 250mbps by day 3. If I simply rebooted the router, the speed shot back up.
I tried various Asus firmware builds, tweaking settings, fixing channels and you name it. Full resets after flashes (factory reset) yet nothing resolved the issue. After owning this thing 7 weeks, I did the RMA route which was a little painful at first but in the end I ended up with a retail box and another unit which also had the same darn issue.
The last step I planned to take before giving up was use the Merlin firmware which as of day 7 now has basically kept me at 866-1300Mbps on a regular basis. 1.3Gbps as I type this up.
Misc note:
I’m using an Asus AC66 PCIE addon card in my PC as the main and only client on the 5GHz network.
I didn't find this specific issue on the forum.
Special thanks to the community on this forum and Merlin for his efforts in building the proper experience on these routers.
ISSUE:
SOLUTION:
Misc note:
