Asus RT-AC68 offered 3.0.0.4.384_45708
joltdude
Interesting when I logged into my RT-AC68 this morning I saw this was avalible and grabbed it
(Got the yellow exclamation in the toolbar)
Current Version : 3.0.0.4.384_45708-g6c4a2e4
ASUS RT-AC68U Firmware Version 3.0.0.4.384.45708
2019/03/29
39.76 MBytes
Security Fix
- Fixed CVE-2018-20334
- Fixed CVE-2018-20336
- Fixed null pointer issue. Thanks for CodeBreaker of STARLabs’ contribution.
- Fixed AiCloud buffer overflow vulnerability. Thanks for Resecurity International's contribution.
Bug Fix
- Fixed AiMesh LAN IP issue when router using IPv6 WAN.
- Fixed AIMesh connection issues.
- Fixed Network Map related issues.
- Fixed Download Master icon disappear issue.
- Fixed LAN PC cannot find router name in My Network Places when enabling Samba service.
- Fixed LAN LED not blinking problem.
Please unzip the firmware file first then check the MD5 code.
MD5: ce1dc4c44b042a452ff368c20ae0dc53
Download link: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AC68U/FW_RT_AC68U_300438445708.zip
** Note: If you head over to Asus, I found it under the drop down for ‘Others’.
Really!? :O
It's more complete: there is the date (2019/03/29) and the consistency (39.76 MBytes) ;)
Since updating my rt-ac1900p I've been getting a squashfs error in my log every 2 min. I've tried rebooting and factory resetting.
Mar 29 23:17:21 kernel: SQUASHFS error: Unable to read page, block 187b0a6, size 4f78
Mar 29 23:19:21 kernel: SQUASHFS error: xz_dec_run error, data probably corrupt
Mar 29 23:19:21 kernel: SQUASHFS error: squashfs_read_data failed to read block 0x187b0a6
Mar 29 23:19:21 kernel: SQUASHFS error: Unable to read data cache entry [187b0a6]
Mar 29 23:19:21 kernel: SQUASHFS error: Unable to read page, block 187b0a6, size 4f78
Squashfs errors usually indicate a read error in flash. Try reflashing your firmware.
Also double check the datestamp, as these errors often occurs following a firmware upgrade - this is normal, as you are overwriting a live filesystem.
The upgrade of my RT-68U went ok.
The system log gave above shown SQUASHFS errors after first startup, now they seems to stay away.
The Network Map seems a bit better then it was with the previous firmware, with another glitch:
The "2" is placed at the wrong device, it should be at the RT-N66U which is set as Media Bridge, the Sony Blue-Ray player is wired at the RT-N66U.
Mine is running for over an hour now after the firmware upgrade, with no more new messages in the System Log for the past hour.
I've been messing with this firmware a bit more. When I shut Ai Protection, Adaptive QoS and Traffic Analyzer off the errors stop but as soon as I turn one of them on they start showing up again. The same thing happens after a factory reset as well.
Ai Protection, Adaptive QoS and Traffic Analyzer are all off in my router, that may explain the lack of errors.
I have the same issue with my AI mesh system after upgrading to the new firmware, how to send this issue to Asus team?
I have the SQUASHFS error as well. I do have aiProtection on.
seeing the same errors on rt-ac68u, every 2 minutes. On a good note, ipv6 is fixed again.
