I followed a thread on reddit and set up DNSFilter and forcing all requests both normal and hardcoded/DNS over HTTPS queries through my router. It works great. I do however have a few queries I am hoping some of you could address.
As mentioned, everything seems to go through primary pihole and any query that has hardcoded dns forces itself back to the router which comes up as a query under my router. Awesome.
I've been thinking about redundancy, I was trying to maintain a 2nd pihole using pihole-gemini? Doesn't seem to work with the new Pihole version 5. Nonetheless I also followed a guide and I also have a pihole running in the cloud. I was thinking of pointing my 2nd DNS server to that cloud based server, in the event of a corrupt sd card or the primary pi failing. However, with the DNSfilter enabled I'd drop my connection as when it would go down, so would too my DNS queries. As a workaround I do have WAN access to my router so I can access it at anytime and disable the DNSFilter to enable DNS queries to continue and point to my 2nd DNS server.
There isn't anyway to force all clients to primary local pihole and in the event if it goes offline, dns queries would then go to the pi in the cloud or a 2nd local pihole with the same forced requests through the router or is that a limitation of DNS filter? I don't want to disable it all together and run 2 piholes as I want all the stats on one and save the other for reduncany if it is ever required. Hope this makes sense, if you need any clarification please let me know. Thanks.
