Hello!
I´ve Merlin 380.65_4 installed on my RT AC68U. I´m using it as OpenVPN Server and Client. Both Tunnels are working great. I´ve only one Problem. When i connect my devices to the OPEN VPN Server i can´t access the Network which is connected with the Open VPN Client function to my Second Location.
I´m not sure but i think i have a routing problem from the VPN Server Subnet to the VPN Client Subnet.
Config:
Local Subnet: 192.168.0.x/24
VPN Server Subnet: 10.8.0.x/24
VPN Client Subnet: 10.1.8.x /24
VPN Server and VPN Client are using different UDP Ports!
On the VPN Server which i connect with my Asus Open VPN Client i see the following error in the log
MULTI: bad source address from client [10.10.2.2], packet dropped
Maybe it can also be a Problem from the VPN Server which i connect with my Asus Router.
Any ideas?
Thanks in advance
Bye
Config:
Any ideas?
Thanks in advance
Bye
