Asus RT-AC68U reboots every 10-15 minutes ?
Kayzah
Hello Community ,
I have a massive problem regarding my Asus RT AC68U , I have the device since like 2months now and it worked perfectly fine for the first 3-4 weeks. Then it started randomly disconnecting like 2-3 times a day. I didnt change any setting in this time so it cant be my fault.However i use Wlan and Lan on the router.
I already called my ISP in this time but they said the Modem works perfectly fine , I also double checked it and my modem seems to working fine even if the router disconnects. Since 2days now , my Router reboots itself every 15 minutes , I reseted it like 10 times by now , downloadest the latest firmware etc.
In my oppionion there´s nothing I can do no more from what I know.
Hopefully some you guys can help me out with this problem .
ROUTER LOG :
Jan 1 02:00:11 syslogd started: BusyBox v1.17.4
Jan 1 02:00:11 kernel: klogd started: BusyBox v1.17.4 (2014-04-14 05:38:42 CST)
Jan 1 02:00:11 kernel: Linux version 2.6.36.4brcmarm (gitserv_asus@wireless-pub1) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Mon Apr 14 05:45:03 CST 2014
Jan 1 02:00:11 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Jan 1 02:00:11 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jan 1 02:00:11 kernel: Machine: Northstar Prototype
Jan 1 02:00:11 kernel: Ignoring unrecognised tag 0x00000000
Jan 1 02:00:11 kernel: Memory policy: ECC disabled, Data cache writealloc
Jan 1 02:00:11 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60416
Jan 1 02:00:11 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Jan 1 02:00:11 kernel: Memory: 255508k/255508k available, 6636k reserved, 0K highmem
Jan 1 02:00:11 syslog: module ledtrig-usbdev not found in modules.dep
Jan 1 02:00:11 syslog: module leds-usb not found in modules.dep
Jan 1 02:00:11 kernel: Virtual kernel memory layout:
Jan 1 02:00:11 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jan 1 02:00:11 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Jan 1 02:00:11 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Jan 1 02:00:11 kernel: vmalloc : 0xd0800000 - 0xf0000000 ( 504 MB)
Jan 1 02:00:11 kernel: lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
Jan 1 02:00:11 kernel: modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Jan 1 02:00:11 kernel: .init : 0xc0008000 - 0xc003d000 ( 212 kB)
Jan 1 02:00:11 kernel: .text : 0xc003d000 - 0xc03aa000 (3508 kB)
Jan 1 02:00:11 kernel: .data : 0xc03c2000 - 0xc03e4f40 ( 140 kB)
Jan 1 02:00:11 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
Jan 1 02:00:11 kernel: Mount-cache hash table entries: 512
Jan 1 02:00:11 kernel: CPU1: Booted secondary processor
Jan 1 02:00:11 kernel: Found a AMD NAND flash:
Jan 1 02:00:11 kernel: Total size: 128MB
Jan 1 02:00:11 kernel: Block size: 128KB
Jan 1 02:00:11 kernel: Page Size: 2048B
Jan 1 02:00:11 kernel: OOB Size: 64B
Jan 1 02:00:11 kernel: Sector size: 512B
Jan 1 02:00:11 kernel: Spare size: 16B
Jan 1 02:00:11 kernel: ECC level: 8 (8-bit)
Jan 1 02:00:11 kernel: Device ID: 0x 1 0xf1 0x 0 0x1d 0x 1 0xf1
Jan 1 02:00:11 kernel: bio: create slab <bio-0> at 0
Jan 1 02:00:11 kernel: PCI: no core
Jan 1 02:00:12 kernel: PCI: Fixing up bus 0
Jan 1 02:00:12 kernel: PCI: Fixing up bus 1
Jan 1 02:00:12 kernel: PCI: Fixing up bus 2
Jan 1 02:00:12 kernel: VFS: Disk quotas dquot_6.5.2
Jan 1 02:00:12 syslog: module vfat not found in modules.dep
Jan 1 02:00:12 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jan 1 02:00:12 kernel: pflash: found no supported devices
Jan 1 02:00:12 kernel: bcmsflash: found no supported devices
Jan 1 02:00:12 kernel: Boot partition size = 524288(0x80000)
Jan 1 02:00:12 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Jan 1 02:00:12 kernel: nflash: squash filesystem with lzma found at block 28
Jan 1 02:00:12 kernel: Creating 4 MTD partitions on "nflash":
Jan 1 02:00:12 kernel: 0x000000000000-0x000000080000 : "boot"
Jan 1 02:00:12 kernel: 0x000000080000-0x000000200000 : "nvram"
Jan 1 02:00:12 kernel: 0x000000200000-0x000002000000 : "linux"
Jan 1 02:00:12 kernel: 0x00000039e728-0x000002000000 : "rootfs"
Jan 1 02:00:12 kernel: === PPTP init ===
Jan 1 02:00:12 kernel: Registering the dns_resolver key type
Jan 1 02:00:12 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Jan 1 02:00:12 kernel: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Jan 1 02:00:12 kernel: Available 7 bytes at (off,len):
Jan 1 02:00:12 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Jan 1 02:00:12 kernel: Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
Jan 1 02:00:12 kernel: Creating 1 MTD partitions on "brcmnand":
Jan 1 02:00:12 kernel: 0x000002000000-0x000008000000 : "brcmnand"
Jan 1 02:00:12 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Jan 1 02:00:12 kernel: ctf: module license 'Proprietary' taints kernel.
Jan 1 02:00:12 kernel: Disabling lock debugging due to kernel taint
Jan 1 02:00:12 kernel: et_module_init: passivemode set to 0x0
Jan 1 02:00:12 kernel: et_module_init: txworkq set to 0x1
Jan 1 02:00:12 kernel: et_module_init: et_txq_thresh set to 0x400
Jan 1 02:00:12 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.86 (r456083)
Jan 1 02:00:12 kernel: wl_module_init: passivemode set to 0x0
Jan 1 02:00:12 kernel: wl_module_init: txworkq set to 0x1
Jan 1 02:00:12 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.86 (r456083)
Jan 1 02:00:12 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.86 (r456083)
Jan 1 02:00:12 kernel: SCSI subsystem initialized
Jan 1 02:00:12 kernel: jnl: driver (lke_8.9.0, Apr 14 2014 06:25:47, LBD=ON) loaded at bf5bb000
Jan 1 02:00:12 kernel: ufsd:: trace mask set to 0000000f
Jan 1 02:00:12 kernel: ufsd: driver (lke_8.9.0 lke_8.9.0_r225078_b43, LBD=ON, delalloc, acl, ioctl, ugm, sd(1), wb, tr) loaded at bf5c8000
Jan 1 02:00:12 kernel: NTFS support included
Jan 1 02:00:12 kernel: Hfs+/HfsJ support included
Jan 1 02:00:12 kernel: optimized: speed
Jan 1 02:00:12 kernel: Build_for__ASUS_PRODUCTS_003_lke_8.9.0_r225078_b43
Jan 1 02:00:12 kernel: xhci_hcd 0000:00:0b.0: Failed to enable MSI-X
Jan 1 02:00:12 kernel: xhci_hcd 0000:00:0b.0: failed to allocate MSI entry
Jan 1 02:00:12 kernel: usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
Jan 1 02:00:13 syslog: module proxyarp not found in modules.dep
Jan 1 02:00:14 stop_nat_rules: apply the redirect_rules!
Jan 1 02:00:14 WAN Connection: ISP's DHCP did not function properly.
Jan 1 02:00:14 RT-AC68U: start httpd
Jan 1 02:00:15 syslog: Generating SSL certificate...
Jan 1 02:00:20 miniupnpd[550]: HTTP listening on port 47815
Jan 1 02:00:20 miniupnpd[550]: Listening for NAT-PMP traffic on port 5351
Jan 1 02:00:20 disk monitor: be idle
Jan 1 02:00:21 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jan 1 02:00:22 kernel: nf_conntrack_rtsp v0.6.21 loading
Jan 1 02:00:22 kernel: nf_nat_rtsp v0.6.21 loading
Jan 1 02:00:22 rc_service: udhcpc 566:notify_rc stop_upnp
Jan 1 02:00:22 miniupnpd[550]: received signal 15, good-bye
Jan 1 02:00:22 rc_service: udhcpc 566:notify_rc start_upnp
Jan 1 02:00:22 rc_service: waitting "stop_upnp" via udhcpc ...
Jan 1 02:00:23 rc_service: udhcpc 566:notify_rc stop_ntpc
Jan 1 02:00:23 rc_service: udhcpc 566:notify_rc start_ntpc
Jan 1 02:00:23 rc_service: waitting "stop_ntpc" via udhcpc ...
Jan 1 02:00:23 miniupnpd[625]: HTTP listening on port 59675
Jan 1 02:00:23 miniupnpd[625]: Listening for NAT-PMP traffic on port 5351
Jan 1 02:00:24 WAN Connection: WAN was restored.
May 1 19:55:11 dhcp client: bound 95.89.170.27 via 95.89.170.254 during 5400 seconds.
May 1 19:55:11 rc_service: ntp 629:notify_rc restart_upnp
May 1 19:55:11 rc_service: ntp 629:notify_rc restart_diskmon
May 1 19:55:11 rc_service: waitting "restart_upnp" via ntp ...
May 1 19:55:11 miniupnpd[625]: received signal 15, good-bye
May 1 19:55:11 miniupnpd[641]: HTTP listening on port 49017
May 1 19:55:11 miniupnpd[641]: Listening for NAT-PMP traffic on port 5351
May 1 19:55:13 disk monitor: be idle
Thanks for the answers and any help !!!
I always try first thing on a situation like this, sort of shot gunning the trouble. Replace
AC adapter if you have any spare one around. Flaky adapter can cause all kinda funnies.
eBay shows some 5 amp. rated 12V DC adapters for universal use. Some like this will be
good replacement.
Im using the latest firmware at the moment : 3.0.0.4.374_5517-g302e4dc
Thanks for answers so far !!
Cant my router log tell you guys anything special ?
Regards
Regards
5517 is not the latest firmware 3.0.0.4.374.5656 is the latest and it works good.
well where Can I download it ? I am looking for a download now anyway .
However it obviously dont work fine for me .... :(
good replacement.
These routers don't use 12V adapters. They are 19V, if I'm not mistaken.
Several people have posted elsewhere that the routers update feature was getting 5517 even after 5656 was released and 5517 was removed from the support page. I have read that 5517 was found unstable almost as soon as it was posted and 5656 is the solution. Unfortunately the server used for these built in update features is not quickly configured. I have had over 10 days now with 5656 and no reboots.
