driftmotion
Hey guys,
I want to start off with being overwhelmed by the amount of information here. However, I don't think I've seen any threads that address my issue. So I'm hoping you guys can help me out here. I think? I have an idea on what's going on, but not 100% sure.
I have a RT-AC68U router running on the latest firmware (3.0.0.4.380.1842). I don't have a good wired internet connection (Verizon DSL with max 1Mb down, very unstable because it's far from the station), so I got a Sprint WiFi Hot Spot instead. It's a ZTE MF975S.
Connecting it through the WiFi hot spot itself (via WiFi or USB directly), I can get up to 13Mb down/3Mb up according to speedtest.net. Without moving the pocket WiFi , connecting it to the Asus RT-68U router and setting it up as the USB WAN into the USB 2.0 port (2.0 or 3.0 port does not make a difference), the download speed reduces to less than 1Mb down/ similar up speed. Ping is about the same at around 50ms. No other device was connected to the router when I was testing the speed.
Another thing I noticed is that the ZTE MF975S is not on the compatibility list (http://www.asus.com/event/networks_3G4G_support/). Therefore I'm suspecting that since it's technically not compatible, therefore the speed is significantly reduced. Again, I'm not having trouble setting up the WiFi Hot Spot device as the USB WAN, just issue with the slow speed.
Adaptive QoS is off, but turning it on does not make a difference.
TD;DR Sprint ZTE MF975S WiFi Hot Spot is fast by itself, but once connected to the RT68U via USB port as USB Wan, Down speed is reduced to less than 1Mb/s.
Any ideas?
Any ideas?
