ASUS RT-AC68U unable to access QNAP S-653 Pro remotely
Exactly the same issues for me with ac88u an a ts-253b. I registered a asuscomm.com ddns-adress and set up a open-vpn-connection (tap) an everythings works fine.
I have QNAP TS251+, and bought RT-86U a few days ago, install the Merlin but have a problem with Web connectivity.
My UPnP on Router is enabled.
So I added Port Forwarding, but still in the same way.
2018-12-02-19-39-36-ASUS-Wireless-Router-RT-AC86-U-Virtual-Server-Port-Forwarding.png
WEB1.png" alt="WEB1" border="0">
By default Asuswrt refuses to forward ports below 1024 through UPnP, for security reasons. This is configurable on the WAN page.
i'm trying to setup QVPN to access a QNAP nas from android mobile.
qvpn definitely detects the NAS fine (as the geo location ip correctly updates). but there is a problem when trying to connect, which it fails to do.
So it feels like the issue is a firewall problem?
Any tips for configuring the asus ac68u rt merlin settings for it?
I already port forwarded the port required for qbelt (UDP right?) also i check the credentials, everything seems to be entered correctly. but it can't connect.
All i can think of is maybe i entered the port forwarding wrongly?
I did not bother using UPNP for setting it up, since i don't consider it a safe feature to use, so i rather do it manually.
Any suggestions?
