mmelbourne
I have recently purchased a RT-AC68U (h/w Rev. A2), and running Merlin 380.58.
I am connecting it toa Virgin Media Hub 3.0 in Modem Mode.
Running a constant ping to external destinations shows that traffic is dropped every few minutes (other traffic is also effected, e.g. DNS queries), and recovers after a few seconds to only fail again minutes later. (This is all over wired connections; I eliminated wireless as an issue early on).
If I replace the RT-AC68U with a Cisco ASA firewall, then the traffic drops do not occur. Nor do they occur if I connect the Hub 3.0 (Cable Modem) directly to a laptop in modem mode.
My next step is to probably span the ASUS WAN port, to check whether the packets make it onto the wire when connectivity is lost. There are no entries in the log on the router when connectivity is lost, but the Network Map does detect that connectivity is down.
This is completely baffling as I can't really blame the cable modem as another device works. I have also tried placing a dumb switch inbetween the cable modem and the ASUS router's WAN port in case it's some weird electrical interop issue.
Any ideas?
Kind regards,
Matt
Any ideas?
Kind regards,
Matt
