ASUS RT-AC86U firmware release 3.0.0.4.384.45713
No....you no know comment or creat topic....i post reply and mode or admin snb no acept....i see unfair here
You used blacklisted words like sh*t, thats why mod approval is required before your post will be published.
Mods bad, telling you. One of my posts explaining something around parental control settings got blocked too, @thiggins bad guy :D
started seeing this for the first time today - now happening several times per hour.
i've always used 2.4 ch.11(20/40) and 5.0 ch.161(80) without any problems - yet o_O
Nov  6 14:33:21 acsd: COEX: downgraded chanspec 0x1909 to 0x100b: channel 5 used by exiting BSSs
Nov  6 14:33:21 acsd: selected channel spec: 0x100b (11)
Nov  6 14:33:21 acsd: Adjusted channel spec: 0x100b (11)
according to advanced.settings/wireless/site.survey no other router is on my channels,
however a few of my lan streaming sticks and printers with casting features can be seen.
Excessive Auto channel scanning is known issue with this version. Are you using Auto channels?
AiProtection also consumes memory, in my experience.
OE
That's really odd. First time I've seen the message and auto channel not turned on. The message looks like it changed from channel 5 to 11 and you've always had it hardcoded to 11 as shown in your screen shots?
yes, since october 2018 when i first put this ac3100 into service.
i always use fixed channels to "muscle" my clueless neighbors out
who are usually set on auto by their isp provided routers.
in case it matters, i'm using all 4+4 ssid's my router can host,
each of the 8 ssid's has a unique name and password.
Nov  7 20:38:22 acsd: COEX: downgraded chanspec 0x1909 to 0x100b: channel 4 used by exiting BSSs
Nov  7 20:38:22 acsd: selected channel spec: 0x100b (11)
Nov  7 20:38:22 acsd: Adjusted channel spec: 0x100b (11)
Nov  7 20:39:39 acsd: COEX: downgraded chanspec 0x1909 to 0x100b: channel 4 used by exiting BSSs
Nov  7 20:39:39 acsd: selected channel spec: 0x100b (11)
Nov  7 20:39:39 acsd: Adjusted channel spec: 0x100b (11)
i just wanted to post some additional observations regarding this 2.4 ghz radio ongoing issue;
i noticed when people get home, particularly with smartphones that know both 2.4 and 5.0 ssids (saw this with samsung(ac) and iphone(n)) who use the 5.0 ssid but instead got on the 2.4 radio this triggers that sequence of channel changing errors, but it seems to calm down after a minute.
i also noticed when a fringe device, meaning a distant 2.4 device is having difficulty remaining online with the 2.4 ssid radio, such as an a 20m distant roku that is using dual channel N only this may trigger a that sequence repeatedly over a long duration till the radio fails to work and the router has to be rebooted.
what i'm doing is checking my log daily, and seeing the correlation between when is this error and how long ago a roaming or fringe device rejoined the 2.4 radio, thus distinguish a pattern of behavior so i know when i may need to preemptively reboot the router in order to anticipate such a 2.4 radio failure
nov'13: i noticed a pattern where these errors repeatedly happen when a specific iphone that usually uses 5ghz is using 2.4ghz instead (different ssid). i keep telling my kid to "forget" the 2.4ghz ssid, and only use the 5ghz one, but somehow she keeps using 2.4ghz every few days, which then kicks off a flurry of these errors that ultimately destabilize the radio and force me to reboot the router.
