Asus RT-AC86U signature updates and reboots
lalala2
It appears that the RT-AC86U reboots every time there is a signature version upgrade, which happens every several days.
This is info from the firmware upgrade tab of firmware 3.0.0.4.384_21140:
Signature Version
2.086 Updated : 2018/09/02 01:37
I need a stable router that doesn't reboot. Is there a way to turn off these signature updates?
Signature Version
Where does this appear? I haven't noticed this on the four 86Us I've worked on.
OE
OE
It only appears if you use any of the Trend Micro-powered features that requires it (for instance Adaptive QoS).
Thanks... that explains that! I hope ASUS doesn't think of anything else to cram into their routers! :rolleyes:
OE
Why does the router need to reboot for a signature update? If a computer needed a reboot for every antivirus signature update, it would be rebooting constantly all day long every day
It doesn't. What indicates the router actually rebooted?
Exactly. Mine does not reboot for signature updates, so not sure what is up with the OP's router.
Some people confuse a reboot with a restart of the wireless stack, that's why I was asking.
The uptime counter resets and the system log shows the time resetting to a prior period and then finally coming back to the present day.
However, I just looked at it again and it seems the router resets every 4-5 days independently of the signature version update. There seems to be some other issue with my router.
maybe you have enabled the scheduler for reboot?
to check,
it's under admin -> system -> Enable Reboot Scheduler
if it's not the case,
I will try to do a power cycle + nvram clear and reconfigure the router from there
power of the router for 30+ sec, hold wps button while powering on
wait till power led start blinking/flashing then release the wps button
wait till it's reboot and reconfigure from there.
Reviving this thread with hopes to find out the reason behind these reboots.
The longest uptime I've been able to achieve with the 86U is around 10 days, normally when I check it's uptime it's either a few days or just hours, and for some unknown reason it has rebooted.
This happens on every release that I'm aware of, I've done a full factory reset and auto reboot scheduler is and alwasys has been disabled.
Possible causes:
FreshTJ's QOS script?
Skynet firewall script?
USB connected hard drive?
Is there a method to debug this and gather more information without cracking it open and connecting a serial cable?
Here's a snippet from the router's log just before a reboot.
Nov 16 23:09:11 dnsmasq-dhcp[800]: DHCPREQUEST(br0) 192.168.1.181 00:bb:3a:8f:16:d0
Nov 16 23:09:11 dnsmasq-dhcp[800]: DHCPACK(br0) 192.168.1.181 00:bb:3a:8f:16:d0
Nov 16 23:09:17 dnsmasq-dhcp[800]: DHCPREQUEST(br0) 192.168.1.186 b0:65:bd:9b:08:59
Nov 16 23:09:17 dnsmasq-dhcp[800]: DHCPACK(br0) 192.168.1.186 b0:65:bd:9b:08:59 iPad-41
May  5 07:05:05 syslogd started: BusyBox v1.25.1
May  5 07:05:05 kernel: klogd started: BusyBox v1.25.1 (2018-11-10 00:23:56 CET)
May  5 07:05:05 kernel: Booting Linux on physical CPU 0x0
May  5 07:05:05 kernel: Linux version 4.1.27 (gingernut78@gingernut78-VirtualBox) (gcc version 5.3.0 (Buildroot 2016.02) ) #2 SMP PREEMPT Sat Nov 10 01:28:06 CET 2018
May  5 07:05:05 kernel: CPU: AArch64 Processor [420f1000] revision 0
May  5 07:05:05 kernel: Detected VIPT I-cache on CPU0
May  5 07:05:05 kernel: alternatives: enabling workaround for ARM erratum 845719
May  5 07:05:05 kernel: PERCPU: Embedded 15 pages/cpu @ffffffc01ffd6000 s21376 r8192 d31872 u61440
May  5 07:05:05 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 122112
May  5 07:05:05 kernel: Kernel command line: coherent_pool=1M cpuidle_sysfs_switch
May  5 07:05:05 kernel: PID hash table entries: 2048 (order: 2, 16384 bytes)
May  5 07:05:05 kernel: Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
May  5 07:05:05 kernel: Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
May  5 07:05:05 kernel: Memory: 440208K/495616K available (4678K kernel code, 301K rwdata, 1568K rodata, 228K init, 471K bss, 55408K reserved, 0K cma-reserved)
May  5 07:05:05 kernel: Virtual kernel memory layout:
May  5 07:05:05 kernel:     vmalloc : 0xffffff8000000000 - 0xffffffbdffff0000   (   247 GB)
May  5 07:05:05 kernel:     vmemmap : 0xffffffbe00000000 - 0xffffffbfc0000000   (     7 GB maximum)
May  5 07:05:05 kernel:               0xffffffbe00000000 - 0xffffffbe00700000   (     7 MB actual)
May  5 07:05:05 kernel:     fixed   : 0xffffffbffabfd000 - 0xffffffbffac00000   (    12 KB)
May  5 07:05:05 kernel:     PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000   (    16 MB)
May  5 07:05:05 kernel:     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
May  5 07:05:05 kernel:     memory  : 0xffffffc000000000 - 0xffffffc020000000   (   512 MB)
May  5 07:05:05 kernel:       .init : 0xffffffc00069b000 - 0xffffffc0006d4000   (   228 KB)
May  5 07:05:05 kernel:       .text : 0xffffffc000080000 - 0xffffffc00069a274   (  6249 KB)
May  5 07:05:05 kernel:       .data : 0xffffffc0006d5000 - 0xffffffc000720680   (   302 KB)
May  5 07:05:05 kernel: Preemptible hierarchical RCU implementation.
May  5 07:05:05 kernel:     RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
May  5 07:05:05 kernel: RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
May  5 07:05:05 kernel: NR_IRQS:64 nr_irqs:64 0
May  5 07:05:05 kernel: Architected cp15 timer(s) running at 50.00MHz (phys).
May  5 07:05:05 kernel: clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb8812736b, max_idle_ns: 440795202655 ns
May  5 07:05:05 kernel: sched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 4398046511100ns
May  5 07:05:05 kernel: BRCM Legacy Drivers' Helper, all legacy drivers' IO memories/interrupts should be remapped here
May  5 07:05:05 kernel:      Remapping interrupts...
May  5 07:05:05 kernel:              hwirq      virq
May  5 07:05:05 kernel:                61         5
May  5 07:05:05 kernel:                64         6
May  5 07:05:05 kernel:                66         7
May  5 07:05:05 kernel:                91         8
May  5 07:05:05 kernel:                92         9
May  5 07:05:05 kernel:                93        10
May  5 07:05:05 kernel:                77        11
May  5 07:05:05 kernel:                78        12
May  5 07:05:05 kernel:                79        13
May  5 07:05:05 kernel:                80        14
May  5 07:05:05 kernel:                81        15
May  5 07:05:05 kernel:                82        16
May  5 07:05:05 kernel:                83        17
May  5 07:05:05 kernel:                84        18
May  5 07:05:05 kernel:                85        19
May  5 07:05:05 kernel:                86        20
May  5 07:05:05 kernel:                88        21
May  5 07:05:05 kernel:                96        22
May  5 07:05:05 kernel:                97        23
May  5 07:05:05 kernel:                98        24
May  5 07:05:05 kernel:                99        25
May  5 07:05:05 kernel:               118        26
May  5 07:05:05 kernel:               119        27
May  5 07:05:05 kernel:               106        28
May  5 07:05:05 kernel:               104        29
May  5 07:05:05 kernel:               105        30
May  5 07:05:05 kernel:                76        31
May  5 07:05:05 kernel:               120        32
May  5 07:05:05 kernel:               110        33
May  5 07:05:05 kernel:               148        34
May  5 07:05:05 kernel:               154        35
May  5 07:05:05 kernel:               155        36
May  5 07:05:05 kernel:               156        37
May  5 07:05:05 kernel:               157        38
May  5 07:05:05 kernel:               158        39
May  5 07:05:05 kernel:               159        40
May  5 07:05:05 kernel:                69        41
May  5 07:05:05 kernel:      Remapping IO memories...
May  5 07:05:05 kernel:              phys              virt          size
May  5 07:05:05 kernel:        00000000ff800000  ffffff8000008000  00003000
May  5 07:05:05 kernel:        00000000ff858000  ffffff8000002000  00001000
May  5 07:05:05 kernel:        00000000ff85a000  ffffff800000c000  00001000
May  5 07:05:05 kernel:        00000000ffe00000  ffffff8000040000  00020000
May  5 07:05:05 kernel:        0000000080002000  ffffff800000e000  00001000
May  5 07:05:05 kernel:        0000000080018000  ffffff8000010000  00004000
May  5 07:05:05 kernel:        0000000080200000  ffffff8000018000  00005000
May  5 07:05:05 kernel:        0000000080280000  ffffff8000016000  00001000
May  5 07:05:05 kernel:        0000000082200000  ffffff8000080000  00100000
May  5 07:05:05 kernel:        0000000080080000  ffffff8000200000  00050000
May  5 07:05:05 kernel:        0000000080008000  ffffff8000020000  00003fff
May  5 07:05:05 kernel:        000000008000c000  ffffff8000028000  00003fff
May  5 07:05:05 kernel:        0000000081060000  ffffff8000030000  00004000
May  5 07:05:05 kernel:        0000000080100000  ffffff8000038000  00002000
May  5 07:05:05 kernel:        0000000080010000  ffffff800001e000  00001000
May  5 07:05:05 kernel:        000000008001d000  ffffff800003c000  00001010
May  5 07:05:05 kernel:        000000008001c000  ffffff8000026000  00000448
May  5 07:05:05 kernel: console [ttyS0] enabled
May  5 07:05:05 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=500000)
May  5 07:05:05 kernel: pid_max: default: 32768 minimum: 301
May  5 07:05:05 kernel: Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
May  5 07:05:05 kernel: Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
May  5 07:05:05 kernel: --Kernel Config--
May  5 07:05:05 kernel:   SMP=1
May  5 07:05:05 kernel:   PREEMPT=1
May  5 07:05:05 kernel:   DEBUG_SPINLOCK=0
May  5 07:05:05 kernel:   DEBUG_MUTEXES=0
May  5 07:05:05 kernel: Broadcom Logger v0.1
May  5 07:05:05 kernel: creating mapping for reserved memory phys 0x0c400000 virt 0xffffffc00c400000 size 0x00e00000 for dhd1
May  5 07:05:05 kernel: Do not need to create mapping for reserved memory phys 0x0e000000 size 0x02000000 for buffer
May  5 07:05:05 kernel: creating mapping for reserved memory phys 0x0d200000 virt 0xffffffc00d200000 size 0x00e00000 for flow
May  5 07:05:05 kernel: pmc_init:PMC using DQM mode
May  5 07:05:05 kernel: CPU1: Booted secondary processor
May  5 07:05:05 kernel: Detected VIPT I-cache on CPU1
May  5 07:05:05 kernel: Brought up 2 CPUs
May  5 07:05:05 kernel: SMP: Total of 2 processors activated.
May  5 07:05:05 kernel: CPU: All CPU(s) started at EL2
May  5 07:05:05 kernel: alternatives: patching kernel code
May  5 07:05:05 kernel: devtmpfs: initialized
May  5 07:05:05 kernel: clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
May  5 07:05:05 kernel: NET: Registered protocol family 16
May  5 07:05:05 kernel: cpuidle: using governor ladder
May  5 07:05:05 kernel: cpuidle: using governor menu
May  5 07:05:05 kernel: vdso: 2 pages (1 code @ ffffffc0006dd000, 1 data @ ffffffc0006dc000)
May  5 07:05:05 kernel: DMA: preallocated 1024 KiB pool for atomic allocations
May  5 07:05:05 kernel: ACPI: Interpreter disabled.
May  5 07:05:05 kernel: bcmhs_spi bcmhs_spi.1: master is unqueued, this is deprecated
May  5 07:05:05 kernel: skbFreeTask created successfully
May  5 07:05:05 kernel: gbpm_do_work scheduled
May  5 07:05:05 kernel: ^[[0;34mBLOG v3.0 Initialized^[[0m
May  5 07:05:05 kernel: BLOG Rule v1.0 Initialized
May  5 07:05:05 kernel: Broadcom IQoS v0.1 initialized
May  5 07:05:05 kernel: Broadcom GBPM v0.1 initialized
May  5 07:05:05 kernel: Switched to clocksource arch_sys_counter
Any help is welcome.
Nope. It looks like there's a memory leak
Nov 26 12:57:58 kernel: Mem-Info:
Nov 26 12:57:58 kernel: active_anon:6941 inactive_anon:0 isolated_anon:0
Nov 26 12:57:58 kernel: active_file:15 inactive_file:17 isolated_file:0
Nov 26 12:57:58 kernel: unevictable:813 dirty:0 writeback:0 unstable:0
Nov 26 12:57:58 kernel: slab_reclaimable:438 slab_unreclaimable:74980
Nov 26 12:57:58 kernel: mapped:93 shmem:0 pagetables:323 bounce:0
Nov 26 12:57:58 kernel: free:5708 free_pcp:326 free_cma:0
Nov 26 12:57:58 kernel: DMA free:22936kB min:20480kB low:25600kB high:30720kB active_anon:27764kB inactive_anon:0kB active_file:8kB inactive_file:4kB unevictable:3252kB isolated(anon):0kB isolated(file):0kB present:495616kB managed:440520kB mlocked:0kB dirty:0kB writeback:0kB mapped:220kB shmem:0kB slab_reclaimable:1752kB slab_unreclaimable:299920kB kernel_stack:2144kB pagetables:1292kB unstable:0kB bounce:0kB free_pcp:1304kB local_pcp:732kB free_cma:0kB writeback_tmp:0kB pages_scanned:252 all_unreclai
Nov 26 12:57:58 kernel: lowmem_reserve[]: 0 0 0
Nov 26 12:57:58 kernel: DMA: 489*4kB (UEM) 237*8kB (UEM) 230*16kB (UEM) 104*32kB (UEM) 51*64kB (UEM) 5*128kB (EM) 0*256kB 0*512kB 0*1024kB 0*2048kB 2*4096kB (R) = 22956kB
Nov 26 12:57:58 kernel: 845 total pagecache pages
Nov 26 12:57:58 kernel: 0 pages in swap cache
Nov 26 12:57:58 kernel: Swap cache stats: add 0, delete 0, find 0/0
Nov 26 12:57:58 kernel: Free swap = 0kB
Nov 26 12:57:58 kernel: Total swap = 0kB
Nov 26 12:57:58 kernel: 123904 pages RAM
Nov 26 12:57:58 kernel: 0 pages HighMem/MovableOnly
Nov 26 12:57:58 kernel: 13774 pages reserved
Nov 26 12:57:58 kernel: [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oom_score_adj name
Nov 26 12:57:58 kernel: [ 286] 0 286 4626 22 5 2 0 0 swmdk
Nov 26 12:57:58 kernel: [ 299] 0 299 392 12 4 2 0 0 wdtctl
Nov 26 12:57:58 kernel: [ 331] 0 331 428 14 5 2 0 0 hotplug2
Nov 26 12:57:58 kernel: [ 615] 0 615 2102 81 6 2 0 0 console
Nov 26 12:57:58 kernel: [ 617] 0 617 769 13 6 2 0 0 sh
Nov 26 12:57:58 kernel: [ 685] 0 685 768 21 4 2 0 0 syslogd
Nov 26 12:57:58 kernel: [ 687] 0 687 768 23 5 2 0 0 klogd
Nov 26 12:57:58 kernel: [ 725] 0 725 2102 93 7 2 0 0 wanduck
Nov 26 12:57:58 kernel: [ 730] 0 730 2780 73 10 2 0 0 nt_monitor
Nov 26 12:57:58 kernel: [ 731] 0 731 1290 41 5 2 0 0 protect_srv
Nov 26 12:57:58 kernel: [ 732] 0 732 2614 84 7 2 0 0 netool
Nov 26 12:57:58 kernel: [ 742] 0 742 2292 97 8 2 0 0 nt_center
Nov 26 12:57:58 kernel: [ 748] 0 748 1938 206 8 2 0 0 nt_actMail
Nov 26 12:57:58 kernel: [ 751] 0 751 581 24 5 2 0 0 dropbear
Nov 26 12:57:58 kernel: [ 753] 0 753 696 41 5 2 0 0 eapd
Nov 26 12:57:58 kernel: [ 755] 0 755 846 147 5 2 0 0 nas
Nov 26 12:57:58 kernel: [ 756] 0 756 2102 81 8 2 0 0 wpsaide
Nov 26 12:57:58 kernel: [ 757] 0 757 1008 45 6 2 0 0 wlc_nt
Nov 26 12:57:58 kernel: [ 760] 0 760 728 50 5 2 0 0 bsd
Nov 26 12:57:58 kernel: [ 766] 0 766 1099 48 5 2 0 0 wlceventd
Nov 26 12:57:58 kernel: [ 769] 0 769 743 46 5 2 0 0 acsd
Nov 26 12:57:58 kernel: [ 771] 0 771 687 31 5 2 0 0 dhd_monitor
Nov 26 12:57:58 kernel: [ 774] 65534 774 588 58 5 2 0 0 dnsmasq
Nov 26 12:57:58 kernel: [ 781] 0 781 768 27 5 2 0 0 crond
Nov 26 12:57:58 kernel: [ 794] 0 794 772 56 5 2 0 0 avahi-daemon
Nov 26 12:57:58 kernel: [ 799] 0 799 685 33 4 2 0 0 infosvr
Nov 26 12:57:58 kernel: [ 801] 0 801 1086 499 6 2 0 0 sysstate
Nov 26 12:57:58 kernel: [ 802] 0 802 2159 104 7 2 0 0 watchdog
Nov 26 12:57:58 kernel: [ 804] 0 804 1033 428 5 2 0 0 rstats
Nov 26 12:57:58 kernel: [ 830] 0 830 767 47 5 2 0 0 lld2d
Nov 26 12:57:58 kernel: [ 847] 0 847 1329 200 6 2 0 0 networkmap
Nov 26 12:57:58 kernel: [ 850] 0 850 1945 88 8 2 0 0 mastiff
Nov 26 12:57:58 kernel: [ 851] 0 851 2102 81 7 2 0 0 bwdpi_check
Nov 26 12:57:58 kernel: [ 852] 0 852 2102 86 8 2 0 0 hour_monitor
Nov 26 12:57:58 kernel: [ 856] 0 856 2874 101 9 2 0 0 roamast
Nov 26 12:57:58 kernel: [ 869] 0 869 888 49 6 2 0 0 lldpd
Nov 26 12:57:58 kernel: [ 873] 65534 873 831 38 6 2 0 0 lldpd
Nov 26 12:57:58 kernel: [ 903] 0 903 2720 123 9 2 0 0 cfg_server
Nov 26 12:57:58 kernel: [ 1041] 0 1041 2102 88 7 2 0 0 ntp
Nov 26 12:57:58 kernel: [ 1130] 0 1130 5622 689 16 2 0 0 dcd
Nov 26 12:57:58 kernel: [ 1144] 0 1144 2343 243 8 2 0 0 wred
Nov 26 12:57:58 kernel: [ 1192] 0 1192 2102 83 7 2 0 0 bwdpi_wred_aliv
Nov 26 12:57:58 kernel: [ 2035] 0 2035 479 17 4 2 0 0 mcpd
Nov 26 12:57:58 kernel: [ 2296] 0 2296 2102 82 7 2 0 0 usbled
Nov 26 12:57:58 kernel: [ 2297] 0 2297 1875 52 7 2 0 0 u2ec
Nov 26 12:57:58 kernel: [ 2298] 0 2298 698 29 6 2 0 0 lpd
Nov 26 12:57:58 kernel: [ 2300] 0 2300 2102 87 7 2 0 0 disk_monitor
Nov 26 12:57:58 kernel: [ 4377] 0 4377 2027 103 6 2 0 0 httpds
Nov 26 12:57:58 kernel: [ 4379] 0 4379 3619 1710 11 2 0 0 httpd
Nov 26 12:57:58 kernel: [ 8445] 0 8445 579 56 5 2 0 0 miniupnpd
Nov 26 12:57:58 kernel: [31031] 0 31031 427 14 5 2 0 0 tcd
Nov 26 12:57:58 kernel: [ 886] 0 886 146 1 1 1 0 0 sh
Nov 26 12:59:26 roamast: eth5: add client [2c:1f:23:27:dd:5c] to monitor list
Nov 26 13:14:20 roamast: eth6: add client [2c:1f:23:27:dd:5c] to monitor list
Nov 26 15:29:32 kernel: dcd triggered out of memory codition (oom killer not called): gfp_mask=0x2d2, order=0, oom_score_adj=0
At least in my case looks like I had a failing drive attached, NTFS drive removed from router and tested in Windows, was absolutely full of bad sectors.
Since I've swithced it for a healthy drive I've been stable with an uptime of 12 days so far.
Sorry to resurrect an old thread but I am having this issue. Was surfing the net and suddenly it all froze and then the WiFi dropped and came back. Looked into the router logs and it had rebooted as the uptime was only at about a minute by the time I had logged in. When I saw this thread after googling 86U rebooting I noticed my signature had updated right as I had the reboot.
I have a brand new (less than 2 weeks old) RT-AC86U it was a replacement for my RT-AC68U which was starting to show its age a bit. I am running the latest Merlin update which I did a full factory reset and setup just after I installed it so the router is as clean installed as possible. I have AI Protect, Adaptive QOS, and AI Mesh with the 68U enabled. This config (apart from AI Mesh) is the same as my old 68U which never rebooted by itself when the signature updated, in fact the 68U was rock solid stable and rarely rebooted itself if ever.
Do I have dodgy hardware or is this something I can fix in the software? I chose the 86U in the hope that it would be a modern more powerful update to my 68U and for the most part it is apart from this issue.
Strange. I've got a 2017 AC86U and it doesn't reboot after a Trend Micro Signature update. I've never seen it do this, going back many firmware versions now (currently Merlin 384.18). For example, the signature updated at 2am this morning and my router currently has an uptime of 24 days, which was the last time I caused it to reboot myself.
Yeah its an odd one for sure, I’ve only had it a couple of weeks and its rebooted a couple of times.
Today I did the nuclear option and put the router into recovery mode and reflashed the latest @RMerlin release and then did the WPS button NVRAM reset before setting up again.
I have it configured the same as before so hopefully the NVRAM reset might fix this issue, although when I set it up the first time I updated to the latest @RMerlin via the Web Interface and did the factory reset via the web interface after the update before fully setting it up so fingers crossed it works now.
I shall be watching the uptime counter with great interest over the next few days.
Also noticed an odd quirk of the 86U vs my older 68U on the 68U it used to live on channel 100 pretty much all the time as it was the only router in the area able to use the DFS channels (everybody else has ISP routers which only do 36-48) however on the 86U it starts up around channel 100-108 but eventually drops to channel 48 and stays there.
I do live near a small airfield so it could be the DFS system doing its job however the 68U never had this issue. The only difference in setup this time is that I have AIMesh running with the older 68U but I don’t think that would cause DFS channels to drop as it starts and sometimes stays on channel 100-108 for a good few hours.
I’m guessing the 86U has better antennas than the 68U so could be detecting radar more and therefore keeping the DFS channels clear? Just wondering why it doesn’t go back to channel 100-108 when the radar clears like its meant to as 36-48 is quite congested around my area. Thankfully channel 48 doesn’t cause any issues but on the older 68U I did observe a much greater signal strength when it was using the DFS channels.
I have had issues with Merlin 384.18 and 384.19 alpha2. In the two instances, latest this morning on alpha2, I had no internet connection on any of my connected devices: Android, iOS, Windows 10 or Linux. The router said it was connected but we were not able to connect to anything internet. I access a server remotely by IP address and that did not work. Did a reboot with no success so flashed stock Asus firmware.
Seems that since AMTM was incorporated into Merlin I have not had good success with the firmware. The latest Asus firmwares have been very stable for me. Would like to have DoT builr into the router but for now I am using Pi-Hole with Stubby DoT which works very well!
