Aug 5 17:09:13 rc_service: httpd 796:notify_rc start_vpnclient2
Aug 5 17:09:13 ovpn-client2[8122]: OpenVPN 2.4.7 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jul 31 2019
Aug 5 17:09:13 ovpn-client2[8122]: library versions: OpenSSL 1.1.1c 28 May 2019, LZO 2.08
Aug 5 17:09:13 ovpn-client2[8123]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Aug 5 17:09:13 ovpn-client2[8123]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Aug 5 17:09:13 ovpn-client2[8123]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Aug 5 17:09:13 ovpn-client2[8123]: TCP/UDP: Preserving recently used remote address: [AF_INET]185.143.230.224:1194
Aug 5 17:09:13 ovpn-client2[8123]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Aug 5 17:09:13 ovpn-client2[8123]: UDP link local: (not bound)
Aug 5 17:09:13 ovpn-client2[8123]: UDP link remote: [AF_INET]185.143.230.224:1194
Aug 5 17:09:13 ovpn-client2[8123]: TLS: Initial packet from [AF_INET]185.143.230.224:1194, sid=d00c2351 d4ea2eb7
Aug 5 17:09:13 ovpn-client2[8123]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Aug 5 17:09:13 ovpn-client2[8123]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Aug 5 17:09:13 ovpn-client2[8123]: VERIFY OK: depth=1, C=PA, O=NordVPN, CN=NordVPN CA3
Aug 5 17:09:13 ovpn-client2[8123]: VERIFY KU OK
Aug 5 17:09:13 ovpn-client2[8123]: Validating certificate extended key usage
Aug 5 17:09:13 ovpn-client2[8123]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Aug 5 17:09:13 ovpn-client2[8123]: VERIFY EKU OK
Aug 5 17:09:13 ovpn-client2[8123]: VERIFY OK: depth=0, CN=de546.nordvpn.com
Aug 5 17:09:13 ovpn-client2[8123]: Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Aug 5 17:09:13 ovpn-client2[8123]: [de546.nordvpn.com] Peer Connection Initiated with [AF_INET]185.143.230.224:1194
Aug 5 17:09:14 ovpn-client2[8123]: SENT CONTROL [de546.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Aug 5 17:09:14 ovpn-client2[8123]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 103.86.96.100,dhcp-option DNS 103.86.99.100,sndbuf 524288,rcvbuf 524288,explicit-exit-notify,comp-lzo no,route-gateway 10.8.3.1,topology subnet,ping 60,ping-restart 180,ifconfig 10.8.3.2 255.255.255.0,peer-id 0,cipher AES-256-GCM'
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: timers and/or timeouts modified
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: explicit notify parm(s) modified
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: compression parms modified
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Aug 5 17:09:14 ovpn-client2[8123]: Socket Buffers: R=[524288->1048576] S=[524288->1048576]
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: --ifconfig/up options modified
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: route options modified
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: route-related options modified
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: peer-id set
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: adjusting link_mtu to 1657
Aug 5 17:09:14 ovpn-client2[8123]: OPTIONS IMPORT: data channel crypto options modified
Aug 5 17:09:14 ovpn-client2[8123]: Data Channel: using negotiated cipher 'AES-256-GCM'
Aug 5 17:09:14 ovpn-client2[8123]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Aug 5 17:09:14 ovpn-client2[8123]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Aug 5 17:09:14 ovpn-client2[8123]: TUN/TAP device tun12 opened
Aug 5 17:09:14 ovpn-client2[8123]: TUN/TAP TX queue length set to 1000
Aug 5 17:09:14 ovpn-client2[8123]: /bin/ip link set dev tun12 up mtu 1500
Aug 5 17:09:14 ovpn-client2[8123]: /bin/ip addr add dev tun12 10.8.3.2/24 broadcast 10.8.3.255
Aug 5 17:09:14 ovpn-client2[8123]: updown.sh tun12 1500 1585 10.8.3.2 255.255.255.0 init
Aug 5 17:09:14 openvpn-updown: Forcing 192.168.99.53 to use DNS server 103.86.96.100
Aug 5 17:09:14 rc_service: service 8228:notify_rc updateresolv
Aug 5 17:09:16 ovpn-client2[8123]: /bin/ip route add 185.143.230.224/32 via 77.56.248.1
Aug 5 17:09:16 ovpn-client2[8123]: /bin/ip route add 0.0.0.0/1 via 10.8.3.1
Aug 5 17:09:16 ovpn-client2[8123]: /bin/ip route add 128.0.0.0/1 via 10.8.3.1
Aug 5 17:09:16 openvpn-routing: Configuring policy rules for client 2
Aug 5 17:09:17 ovpn-client2[8123]: Initialization Sequence Completed
