ASUS RT-AC87U Firmware version 3.0.0.4.382.50010
interesting, but no source.
My source say that no chance for AIMesh FW :(
no, asus say that is user build, not asus.
with the latest update i have only 80Mbps speed as opposed to my 300 Mbps with the previous official FW.
Anyone seeing this?
Anyone seeing this?
I have some issues with the speed from 5GHz band.. but yesterday I've restore factory settings and do all settings again manually, so I will test and I see what is going on.
Regards,
Regards,
Almost a week and there's no problem.. Just memory rising from 47- till 55% but don't see any issues.
Someone who try MIMO on this firmware? My router was unresponsive when enable MIMO.. i have to reset the router to be live again...
Sent from my SM-T705 using Tapatalk
Actually I have bad experience with this firmware, after a week wifi gets slow and some devices can't connect to their services. After that I have to reset to defaults and restore configuration. Than everything is fine... This situation is with Aiprotection on, OPEN VPN server ON, 3G USB Failback and Samba on.
Till the moment I have very good experience with 380.7378.. Very stable version with good WiFi performance.
Can you send feedback with system log, wifi log by feedback function ?
Ok. But I'm already on 7378 and I don't think that I keep log from 50010. I'm using some smart devices like Alexa and d-link devices and after a week with 50010 they can't connect to their cloud services.
Sent from my SM-G930F using Tapatalk
Thanks, I can give a one more try to 50010. But I think there is no something wrong at the log files. I've checked few time and I don't see any problem there as messages.
After a week I will send this logs..
Thanks for your help, when you send, add your nickname in description/suggestion field. :)
