ASUS RT-AC88U client list
Meffy
Hello folks. Downloaded and installed latest Merlin firmware because with the asus original firmware i couldnt see all my clients in client list to manually asign. So i tried with latest merlin "RT-AC88U_380.57_0" and even "RT-AC88U_380.58_alpha1" but is still the same. I did a factory reset and then i could see them. After a tried to asign my clients one by one and after a couple of pc reboots (only way to open a url) then the clients dont show up in the list. Never had this trouble with RT-AC87U. How can i solve this problem?
I hope someone can help me.
Thanks!
Meffy
I had the same issue with devices disappearing from the client list, try just leaving it running for a couple days. It resolved the issue itself on my end and my network is kinda complicated, I am using moca, switches and powerline but it ended up finding everything.
I was getting the same on the RT-N66U on the offical firmware.
Was getting this error reported on IE11, although it would not show the list on edge or firefox
Internet explorer 11 reports
Line: 2224
Error: Unable to get property 'isWebServer' of undefined or null reference
Would suggest to me a bug in the firmware, I to did a resinstall and nvram clear, re entered the lot manually and it was ok for a day or 2 then the client list stopped working again. It seems to come and go, it seems to be mostly working now, the list down the side works ok. I figured just ignore it as long as the router works, which it does.
