Asus RT-AC88U rapid flashing power LED light after firmware upgrade
SOLVED!!!! My reset button seems to be not functioning correctly. I had to aggressively push down the reset button to get it to recognize.
Thanks for everybody's help! I am currently running merlin 384.17 and I did the factory reset after firmware update. Thanks again!!!
SOLVED!!!! My power button seems to be not functioning correctly. I had to aggressively push down the reset button to get it to recognize.
You had to aggressively push down the reset button for the power button to work correctly?
Sent from my Pixel 4 XL using Tapatalk
Aggressive push , was not the solution
