ASUS RT-AX82U Firmware version 3.0.0.4.386.49559
1. Improved system stability
2. Supported Safe Browsing in the router app to filter explicit content from search results. You can set it in the router app --> Devices or Family.
3. Fixed anumalous 802.11 frame issues.
Thanks to Kari Hulkko and Tuomo Untinen from The Synopsys Cybersecurity Research Center (CyRC).
Issue was found by using Defensics Fuzz Testing Tool.
Please unzip the firmware file first then check the MD5 code.
MD5: f7e07598e0da86cac73dce8ee54aea1d
RT-AX82U|WiFi 6|ASUS Global
The AX5400 WiFi 6 gaming router recommended for mobile gaming, PS5 compatible. With fast WiFi speed, large coverage and lower lag, free network security and easy setup.
www.asus.com
