Thanks I'll try to find it. Any other stable builds people recommend? I don't need anything special. Just don't want it to drop 10 times a day... Particularly during conference calls.
Same as you, I am looking for some stability with my mesh.
I have four XT8 running the latest official stable firmware (.388.22068). One node has ethernet backhaul and the other two wireless (5GHz, dedicated 20/40/80/160, everything else on auto).
The setup worked flawlessly for like a year, but problems started 4-6 months ago (don't recall exactly when).
One XT8 often disconnects or moves from 5 to 2.4. Many clients are constantly moving around nodes (falling back to the main router even if the signal is weak), to the extent that after fews days, some devices drop from the network and require a physical reboot (e.g. Google Minis do this a lot).
I originally attributed these issues to external factors (new IOT devices and other changes I made at home) and I was about to get the house rewired to have ethernet backhauls everywhere.
Then I found out that pretty much everyone has mesh issues with the .388 releases.
Is it worth giving a try with a factory reset of .388.22068 or it is pointless?
I am keen to hear from those that had problems with this version if they really had better luck after a factory reset.
Better to move back to .386.42095 (I understand there are security concerns)?
Incidentally - a few people suggest a factory reset after a firmware update so the settings default to the factory-optimized from Asus, for the specific firmware version (IMHO if this is true Asus should really address this by forcing new settings over updates). Wouldn't be quicker to copy these values from screenshots of the various wireless/professional setting pages? So much easier than playing around 4 nodes.
