Both latest stock and Merlin have crappy wifi issues. 386.5-2 has been my landing spot for months. It will continue until Asus get their butt into gear and fix the bugs in 388.
No WIFI bugs here. Working as it should work! A few minor GUI bugs. SpeedTest error turned out to be a fault on my ISP end. Speedtest to other sites works as it should.
My test:
First WIFI log early morning before 160 MHz clients connect:
SSID: "xxxxxx"
noise: -87 dBm Channel: 44/80
BSSID: 3C:7C:3F:E1:EB:54 Capability: ESS RRM
Supported Rates: [ 6(b) 9 12 18 24(b) 36 48 54 ]
HE Capable:
Chanspec: 5GHz channel 42 80MHz (0xe22a)
Primary channel: 44
Interference Level: Acceptable
Mode : AP Only
DFS status: state IDLE time elapsed 0ms radar channel cleared by DFS channel 44/160 (0xEA32)
Stations List
idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS BW Tx rate Rx rate Connect Time
4C:82:CF:x9:xx:xx Yes Yes -61dBm n No Yes No No 2 40M 270M 300M 06:29:48
18:4E:CB:C4:xx:xx Yes Yes -76dBm ac Yes Yes Yes Yes 1 80M 390M 6M 10:13:19
08:AA:55:08:xx:xx Yes Yes -59dBm ac Yes Yes Yes Yes 1 80M 390M 6M 12:26:26
EC:CE:x7:35:xx:xx Yes Yes -61dBm ac No Yes No No 1 80M 433.3M 433.3M 12:31:42
F0:B5:x1:A1:xx:xx Yes Yes -52dBm n Yes Yes No No 1 40M 135M 6M 12:58:33
B8:27:EB:62:xx:xx Yes Yes -47dBm ac No Yes No No 1 80M 433.3M 24M 12:59:54
38:81:x7:3D:xx:xx Yes Yes -70dBm n Yes Yes No No 1 40M 150M 6M 13:00:17
Should note that between the first log and the next we had a three hour power failure. My UPS on the router was not going to make an extended outage so I shut the router down after an hour.
Next 160 clients connect but RADAR detected:
SSID: "xxxxxx"
noise: -88 dBm Channel: 36/80
HE Capable:
Chanspec: 5GHz channel 42 80MHz (0xe02a)
Primary channel: 36
Mode : AP Only
DFS status: state IDLE time elapsed 150ms radar channel cleared by DFS channel 36/160 (0xE832)
Stations List
4C:03:4F:9B:xx:xx Yes Yes -58dBm ac No Yes Yes Yes 2 80M 866.7M 866.7M 00:04:23
94:EA:32:53:xx:xx Yes Yes -65dBm ax Yes Yes No No 2 80M 1201.0M 24M 00:27:18
4C:82:CF:x9:xx:xx Yes Yes -67dBm n No Yes No No 2 40M 270M 300M 00:35:28
EC:CE:x7:35:xx:xx Yes Yes -62dBm ac Yes Yes No No 1 80M 390M 24M 00:43:27
44:61:32:E9:xx:xx Yes Yes -57dBm ac No Yes Yes Yes 1 80M 390M 6M 01:00:36
18:4E:CB:C4:xx:xx Yes Yes -71dBm ac Yes Yes Yes Yes 1 80M 390M 6M 01:01:19
F0:B5:x1:A1:xx:xx Yes Yes -54dBm n Yes Yes No No 1 40M 135M 6M 01:01:26
08:AA:55:08:xx:xx Yes Yes -69dBm ac Yes Yes Yes Yes 1 80M 433.3M 6M 01:02:27
2C:1F:23:E3:xx:xx Yes Yes -54dBm n Yes Yes No No 1 40M 135M 24M 01:02:43
B8:27:EB:62:xx:xx Yes Yes -47dBm ac No Yes No No 1 80M 390M 390M 01:03:13
38:81:x7:3D:xx:xx Yes Yes -69dBm n Yes Yes No No 1 40M 135M 6M 01:03:43
Now clients connected at 160 MHz:
SSID: "xxxxxx"
noise: -87 dBm Channel: 36/160
HE Capable:
Chanspec: 5GHz channel 50 160MHz (0xe832)
Primary channel: 36
Mode : AP Only
DFS status: state In-Service Monitoring(ISM) time elapsed 36450ms radar channel cleared by DFS channel 36/160 (0xE832)
Stations List
B4:0E:xE:6D:xx:xx Yes Yes -38dBm ax No Yes Yes Yes 2 160M 2268.5M 490M 00:00:03
4C:03:4F:9B:xx:xx Yes Yes -63dBm ac No Yes Yes Yes 2 160M 1560M 1300M 00:00:33
94:EA:32:53:xx:xx Yes Yes -66dBm ax Yes Yes No No 2 80M 1134.2M 24M 01:16:14
4C:82:CF:x9:xx:xx Yes Yes -70dBm n No Yes No No 2 40M 270M 300M 01:24:24
EC:CE:x7:35:xx:xx Yes Yes -64dBm ac Yes Yes No No 1 80M 390M 24M 01:32:23
44:61:32:E9:xx:xx Yes Yes -60dBm ac No Yes Yes Yes 1 80M 390M 433.3M 01:49:32
18:4E:CB:C4:xx:xx Yes Yes -72dBm ac Yes Yes Yes Yes 1 80M 390M 6M 01:50:15
F0:B5:x1:A1:xx:xx Yes Yes -59dBm n Yes Yes No No 1 40M 135M 6M 01:50:22
08:AA:55:08:xx:xx Yes Yes -71dBm ac Yes Yes Yes Yes 1 80M 390M 6M 01:51:23
2C:1F:23:E3:xx:xx Yes Yes -56dBm n Yes Yes No No 1 40M 135M 24M 01:51:39
B8:27:EB:62:xx:xx Yes Yes -46dBm ac No Yes No No 1 80M 390M 390M 01:52:09
38:81:x7:3D:xx:xx Yes Yes -71dBm n Yes Yes No No 1 40M 135M 6M 01:52:39
My AX86U has been working like this since the 386 code and into the 388 beta and the two releases. We still feel problems others are having are a result of changing the default WIFI settings or your environment. Maybe you have too many IoT devices with crappy firmware?
