In relation to this firmware thread, have you noticed any Wi-Fi performance difference between 46061 and 49447?
Nothing quantitative in particular since I have not actually measured things. After getting the AX86U, I switched to using Smart Connect... you know, changed more than one thing at a time.
The AX86U signals 'looked' a touch less strong than what I recall for the AC86U in the same role/position. But I recently reverted to not using Smart Connect (and not using forced Wireless Mode Auto) and it 'felt' like the AX86U signals recovered to equal and top strength... before installing 49447... or was it at the same time(?)
Connection-wise, my clients are connecting equally well and as good as they get, including at distance... always feels 'best' without Smart Connect and Roaming Assistant. My 2.4 mobile stays connected while mowing the perimeter of a 2 acre lot... upwards of 300+' in some directions, and circling/passing the 2-node AiMesh.
The connection details in the Wireless Log seem similar to the AC86U. It's hard to remember previous numbers and to judge right now because I'm pretty sure hot humid summer conditions are attenuating signals... neighboring WiFi has all but disappeared (leaves ON, too)... in particular, my 77' wireless backhaul is at its weakest but still 'Good to Great'... winter with snow on the ground will be a test point for best.
2.4 numbers (backhaul is NSS 3):
5.0 numbers (backhaul is NSS 4):
Performance-wise, the AX86U is steady and strong. I recently tried to formulate an approach to setting bandwidth and channel with emphasis on fixed first vs auto to better understand the options presented and what they might be doing (to apply them knowingly... to prepare for even more with WiFi6e). And now I'm using this 'formula' to better evaluate 160MHz and DFS with my only ax client... where to best fit it into the available/limited spectrum for all conditions and how long will it hold 160MHz.
My notes show my current configuration. I just unwired my ax client yesterday... my PC and router are in my study together.
THE LEDS ARE TOO BRIGHT!
The AX86U may one day compete with the AC68U on longevity, which would be timely since it has enough to hold most home users until the next 'time to upgrade'. I support a few other family networks and don't want to drag them and me through the AC86U's 24-months-and-it's-over cycle (I just moved two of them to the AX86U), not to mention the AiMesh firmware turnover we've been going through at the same time.
OE
