Release ASUS RT-AX86U Firmware version 3.0.0.4.386_49599 (2022/07/12)
SeriousFamily
ASUS RT-AX86 Series(RT-AX86U/RT-AX86S) Firmware version 3.0.0.4.386.49599
2022/07/12
77.11 MBytes
Bug Fixes and Enhancements:
Improved connection stability
Please unzip the firmware file first then check the MD5 code.
MD5: 130e687475899fae3ea9e44bd00d8bbb
ASUS Firmware download page
Auto upgrade worked OK!
Why advertise something that can't be downloaded here??? :oops:
Wait for it or auto upgrade! Or use the Android or iOS Asus app.
ASUS RT-AX86U firmware version 3.0.0.4.386_49599
2022/07/12
**** MBytes
Waiting for list to show on website (upgrade only shows in gui for now)
ASUS firmware download page
Version 3.0.0.4.386.49599
2022/07/12 77.11 MBytes
Imprtoved connection stability.
https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX86U/FW_RT_AX86U_AX86S_v300438649599.zip
Not very informative and bad spelling due to big fingers.
Think I'll wait a bit to install this one.
Does anyone know if this firmware fixes the 160MHz bandwidth issue in 386.49447?
Dirty upload from webUI.
I notice right off that now you can not set 160MHz and fixed channels. Edit: It's a webUI thing like before. This will need a full review... again.
OE
Whoa! Now they are talking U-NII bands! This could be good!
I'm beginning to think they don't have this figured out anymore than I do!
OE
I'm beginning to think, rather, that they're moving on to what the next evolution of WiFi has become.
It gets better... or worse depending on what this means:
OE
No, they're still figuring out WiFi6 settings!
OE
Yes, the entire world is. Since 1997, I believe.
I'm going to reset before I play with these new options. Who knows what new defaults have come along.
OE
OE
OK, the above went to this after Apply:
I'd say they don't have the UI working properly.
Edit: Router clears 36/160, but allows 36/80. Client connects at 36/80. Same as before, so far... no magically bump up to 36/160 when the client connects.
OE
Seems to be working properly from my perspective here?
This is webUI nonsense:
I'll reset and look again.
OE
Why? It is giving you the options possible (at this stage).
When/as you select/apply further, options are removed/added, and refined.
Nothing weird to me.
