Posted in general VPN forum, but saw now "Use this forum for posts about all versions of this alternative firmware for ASUS wireless routers". Can't find a way to move a thread, so I hope I don't break any rules double posting, but I think this might a better sub-forum
I swapped my old RT-n66u that has been running Merlin firmware for years with two OpenVPN servers (TUN+TAP) and been highly reliably.
I installed a RT-AX86U and flashed Merlin 386.4, made a factory reset and configured everything from scratch and all seamed to work.
Today when I'm away and using my VPN servers I get interruptions all the time. Sometimes it works for <1 min and stops. If I disconnect and reconnect it looks to come back.
I'm connected with one win10 PC and one Android phone.
I have tried:
- disconnect one of the clients and then the other looks to work (only tried for 3-5 minutes, but ok for that time)
- connect both to Server1=TUN and only one of them works. If I disconnect one the other looks to work.
- connect Android to Server1=TUN and PC to Server2=TAP and only one works. If I disconnect one the other looks to work
- create separate users for Android and PC - no difference
When I run a speed test from the Android (WiFiman) it shows >10Mbit bot ways over and over again (only Android connected...)
I have uninstalled the OpenVPN connect app on the phone, restarted it, re-installed and re-configured. No difference.
Can't find any settings regarding number of simultaneous connections
Anyone seen something like this or have any ideas?
Update 18 minutes later:
Started listen to streamed music from Android device and it worked perfect for 15 minutes. Tried to browse the internet and it worked as well.
Connected PC to same VPNserver (TUN) and PC worked. Android could no longer browse the internet (music continued - probably buffered). Disconnected PC and Android could browse the internet again.
I have tried:
