bbunge
Part of the Furniture
ASUS RT-AX86U Pro Firmware version 3.0.0.4.388.23285
Version 3.0.0.4.388.23285
52.56 MB
2023/05/11
ASUS RT-AX86U Pro will qualify for the ‘Engineered for Intel® Evo™’ designation only when used with firmware version 3.0.0.4.388.23285 or greater. Please download that update to ensure the best experience in compatibility and performance. After Firmware upgrade, please do factory reset to apply the changes.
New features:
-Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
-iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
-DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
Bug fixes and functionality modifications:
-Resolved the issue with login and password changes.
-Resolved the IPSec VPN connection issues.
-Resolved the Instant Guard connection issues.
-Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
-Fixed the issue where Traffic Analyzer sometimes couldn't record data.
-Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
-Fine-tuned the description for port status.
-Enabled DynDNS and No-IP DDNS to use IPv6.
-Fixed AiMesh preferred AP identification in site survey results.
-Updated timezone list for Greenland, Mexico, and Iran.
-Modified the USB application option text in dual WAN.
-Allowed WireGuard Server clients to access the Samba server.
-Fixed memory leak issue.
-Enabled the failback function when using the iOS/Android USB backup WAN.
-The ARP response issue has been resolved, along with the connection issue between the router and the ROG Phone 6 and 7.
-Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
Security updates:
-Enabled and supported ECDSA certificates for Let's Encrypt.
-Enhanced protection for credentials.
-Enhanced protection for OTA firmware updates.
-Fixed DoS vulnerabilities in firewall configuration pages. Thanks to Jinghe Gao's contribution.
-Fixed DoS vulerabilities in httpd. Thanks to Howard McGreehan.
-Fixed information disclosure vulnerability. Thanks to Junxu (Hillstone Network Security Research Institute) contribution.
-Fixed CVE-2023-28702 and CVE-2023-28703. Thanks to Xingyu Xu(@tmotfl) contribution.
-Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group - cse hkust contribution.
-Fixed the cfg server vulnerability. Thanks to Swing and Wang Duo from Chaitin Security Research Lab.
-Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.
Please unzip the firmware file, and then verify the checksum.
SHA256: 1039ed080c7970190ca7662b6f6ce1de3a8acd66cc1d16f90060e41ffa68fa1d
52.56 MB
2023/05/11
New features:
Security updates:
