Release ASUS TUF-AX5400 Firmware version 3.0.0.4.388.23285
Yesterday, I did reboot.
After reboot was 136 Mb ram free. One day later is 130 Mb. All logs OFF, so what do router why he loses free RAM...?
Unless the RAM causes network/router issues, stop looking at it. It is being managed as needed best.
I still checks my router. Can You check your LOG, I always see in my LOG this Error when I Turn On QOS.
ERR[qos_start:3363] qos_ops is not registered!
I checked options:
1. Turn On / OFF QOS when router normally works.
2. Turn On / OFF QOS afrer restarts.
Both otions give the same Error.
I send full log to Support...
I'm facing a situation w/ my brand new TUF-AX5400 w/ Dual Wan setup using the latest firmware.
Background: I have two ISP set in my home, one as primary access and other as fallback. I need to connect to each one WLAN to be able to use it.
One of the reasons I decided to buy a new router is to be able to perform Dual Wan setup, so I don't worry about which connection I'm using for work or play.
What I did:
I followed the instructions to set both WAN types (both Automatic DHCP). But the Ethernet LAN is not able to communicate w/ my ISP modem to retrieve a valid DNS address. Both ends are w/ lights on, I changed cables, restarted everything, tried to use different LAN ports, power cycling and even factory reset. My ISP modem shows there there is connection, but the TUF router is not able to request DHCP address. I eve switched primary and secondary it works as expected. The problem is just w/ the Secondary WAN. It shows the following message.
I tried to check logs, but it does not show any error message.
Am I missing something? Should I try to downgrade to previous working version (not sure if possible)?
EDIT: I found a thread w/ a similar issue, from 2016 https://www.snbforums.com/threads/cant-get-dual-wan-to-work.32324/
My Wan Config:
wan0_6rd_prefix=
wan0_6rd_prefixlen=
wan0_6rd_router=
wan0_auth_x=
wan0_auxstate_t=0
wan0_clientid=
wan0_clientid_type=0
wan0_desc=
wan0_dhcp_qry=1
wan0_dhcpenable_x=1
wan0_dns=1.1.1.1 1.0.0.1
wan0_dns1_x=1.1.1.1
wan0_dns2_x=1.0.0.1
wan0_dnsenable_x=0
wan0_enable=1
wan0_expires=2592203
wan0_gateway=192.168.100.1
wan0_gateway_x=0.0.0.0
wan0_gw_ifname=eth4
wan0_gw_mac=[redacted]
wan0_heartbeat_x=
wan0_hostname=
wan0_hwaddr=[redacted]
wan0_hwaddr_x=
wan0_hwname=
wan0_ifname=eth4
wan0_ipaddr=192.168.100.2
wan0_ipaddr_x=0.0.0.0
wan0_is_usb_modem_ready=0
wan0_lease=2592000
wan0_mroute=
wan0_mtu=
wan0_nat_x=1
wan0_netmask=255.255.255.0
wan0_netmask_x=0.0.0.0
wan0_phytype=
wan0_ppp_echo=0
wan0_ppp_echo_failure=10
wan0_ppp_echo_interval=6
wan0_pppoe_ac=
wan0_pppoe_auth=
wan0_pppoe_hostuniq=
wan0_pppoe_idletime=0
wan0_pppoe_ifname=
wan0_pppoe_mru=1492
wan0_pppoe_mtu=1492
wan0_pppoe_options_x=
wan0_pppoe_passwd=
wan0_pppoe_relay=0
wan0_pppoe_service=
wan0_pppoe_username=
wan0_pptp_options_x=
wan0_primary=1
wan0_proto=dhcp
wan0_proto_t=dhcp
wan0_realip_ip=177.220.175.205
wan0_realip_state=2
wan0_route=
wan0_s46_ealen_x=0
wan0_s46_hgw_case=0
wan0_s46_offset_x=6
wan0_s46_peer_x=
wan0_s46_prefix4_x=
wan0_s46_prefix4len_x=0
wan0_s46_prefix6_x=
wan0_s46_prefix6len_x=0
wan0_s46_psid_x=0
wan0_s46_psidlen_x=0
wan0_sbstate_t=0
wan0_state_t=2
wan0_unit=0
wan0_upnp_enable=1
wan0_vendorid=
wan0_vpndhcp=1
wan0_wins=
wan0_xgateway=192.168.100.1
wan0_xipaddr=0.0.0.0
wan0_xnetmask=0.0.0.0
wan1_6rd_ip4size=
wan1_6rd_prefix=
wan1_6rd_prefixlen=
wan1_6rd_router=
wan1_auth_x=
wan1_auxstate_t=0
wan1_clientid=
wan1_clientid_type=0
wan1_desc=
wan1_dhcp_qry=1
wan1_dhcpenable_x=1
wan1_dns=1.1.1.1 1.0.0.1
wan1_dns1_x=1.1.1.1
wan1_dns2_x=1.0.0.1
wan1_dnsenable_x=1
wan1_enable=1
wan1_expires=56
wan1_gateway=0.0.0.0
wan1_gateway_x=0.0.0.0
wan1_gw_ifname=eth0
wan1_gw_mac=
wan1_heartbeat_x=
wan1_hostname=
wan1_hwaddr=[redacted]
wan1_hwaddr_x=
wan1_hwname=
wan1_ifname=eth0
wan1_ipaddr=0.0.0.0
wan1_ipaddr_x=0.0.0.0
wan1_is_usb_modem_ready=0
wan1_mroute=
wan1_mtu=
wan1_nat_x=1
wan1_netmask=0.0.0.0
wan1_netmask_x=0.0.0.0
wan1_phytype=
wan1_ppp_echo=0
wan1_ppp_echo_failure=10
wan1_ppp_echo_interval=6
wan1_pppoe_ac=
wan1_pppoe_auth=
wan1_pppoe_hostuniq=
wan1_pppoe_idletime=0
wan1_pppoe_ifname=
wan1_pppoe_mru=1492
wan1_pppoe_mtu=1492
wan1_pppoe_options_x=
wan1_pppoe_passwd=
wan1_pppoe_relay=0
wan1_pppoe_service=
wan1_pppoe_username=
wan1_pptp_options_x=
wan1_primary=0
wan1_proto=dhcp
wan1_proto_t=dhcp
wan1_realip_ip=
wan1_realip_state=0
wan1_route=
wan1_s46_ealen_x=0
wan1_s46_hgw_case=0
wan1_s46_offset_x=6
wan1_s46_peer_x=
wan1_s46_prefix4_x=
wan1_s46_prefix4len_x=0
wan1_s46_prefix6_x=
wan1_s46_prefix6len_x=0
wan1_s46_psid_x=0
wan1_s46_psidlen_x=0
wan1_sbstate_t=3
wan1_state_t=4
wan1_unit=1
wan1_upnp_enable=1
wan1_vendorid=
wan1_vpndhcp=1
wan1_wins=
wan1_xgateway=0.0.0.0
wan1_xipaddr=0.0.0.0
wan1_xnetmask=0.0.0.0
wan46det_proceeding=0
wan_auth_x=
wan_clientid=
wan_clientid_type=0
wan_desc=
wan_dhcp_qry=1
wan_dhcpenable_x=1
wan_dns=1.1.1.1 1.0.0.1
wan_dns1_x=1.1.1.1
wan_dns2_x=1.0.0.1
wan_dnsenable_x=0
wan_enable=1
wan_gateway=0.0.0.0
wan_gateway_x=0.0.0.0
wan_gw_mac=[redacted]
wan_heartbeat_x=
wan_hostname=
wan_hwaddr=[redacted]
wan_hwaddr_x=
wan_hwname=
wan_ifname=eth4
wan_ifnames=eth4 eth0
wan_ipaddr=0.0.0.0
wan_ipaddr_x=0.0.0.0
wan_mtu=
wan_nat_x=1
wan_netmask_x=0.0.0.0
wan_phytype=
wan_ppp_echo=0
wan_ppp_echo_failure=10
wan_ppp_echo_interval=6
wan_pppoe_ac=
wan_pppoe_auth=
wan_pppoe_hostuniq=
wan_pppoe_idletime=0
wan_pppoe_mru=1492
wan_pppoe_mtu=1492
wan_pppoe_options_x=
wan_pppoe_passwd=
wan_pppoe_relay=0
wan_pppoe_service=
wan_pppoe_username=
wan_pptp_options_x=
wan_primary=0
wan_proto=dhcp
wan_s46_ealen_x=0
wan_s46_offset_x=6
wan_s46_peer_x=
wan_s46_prefix4_x=
wan_s46_prefix4len_x=0
wan_s46_prefix6_x=
wan_s46_prefix6len_x=0
wan_s46_psid_x=0
wan_s46_psidlen_x=0
wan_unit=0
wan_upnp_enable=1
wan_vendorid=
wan_vpndhcp=1
wan_wins=
wandog_delay=0
wandog_enable=1
wandog_fb_count=4
wandog_fb_restart=0
wandog_interval=3
wandog_maxfail=5
wandog_target=www.google.com
wanduck_start_detect=1
wanports=4 0
wans_cap=wan usb lan
wans_dualwan=wan lan
wans_lanport=4
wans_lb_ratio=3:1
wans_mode=fb
wans_routing_enable=0
wans_standby=1
wans_usb_bk=1
wans_usb_bk_act=0
wans_routing_rulelist=
What I did:
My Wan Config:
wan0_6rd_prefix=
wan0_6rd_prefixlen=
wan0_6rd_router=
wan0_auth_x=
wan0_auxstate_t=0
wan0_clientid=
wan0_desc=
wan0_dhcp_qry=1
wan0_dhcpenable_x=1
wan0_dns1_x=1.1.1.1
wan0_dns2_x=1.0.0.1
wan0_dnsenable_x=0
wan0_enable=1
wan0_gw_ifname=eth4
wan0_heartbeat_x=
wan0_hostname=
wan0_hwaddr_x=
wan0_hwname=
wan0_ifname=eth4
wan0_lease=2592000
wan0_mroute=
wan0_mtu=
wan0_nat_x=1
wan0_phytype=
wan0_ppp_echo=0
wan0_pppoe_ac=
wan0_pppoe_auth=
wan0_pppoe_ifname=
wan0_pppoe_mru=1492
wan0_pppoe_mtu=1492
wan0_pppoe_passwd=
wan0_pppoe_relay=0
wan0_pppoe_service=
wan0_primary=1
wan0_proto=dhcp
wan0_proto_t=dhcp
wan0_realip_state=2
wan0_route=
wan0_s46_ealen_x=0
wan0_s46_hgw_case=0
wan0_s46_offset_x=6
wan0_s46_peer_x=
wan0_s46_prefix4_x=
wan0_s46_prefix6_x=
wan0_s46_psid_x=0
wan0_sbstate_t=0
wan0_state_t=2
wan0_unit=0
wan0_upnp_enable=1
wan0_vendorid=
wan0_vpndhcp=1
wan0_wins=
wan1_6rd_ip4size=
wan1_6rd_prefix=
wan1_6rd_prefixlen=
wan1_6rd_router=
wan1_auth_x=
wan1_auxstate_t=0
wan1_clientid=
wan1_desc=
wan1_dhcp_qry=1
wan1_dhcpenable_x=1
wan1_dns1_x=1.1.1.1
wan1_dns2_x=1.0.0.1
wan1_dnsenable_x=1
wan1_enable=1
wan1_expires=56
wan1_gw_ifname=eth0
wan1_gw_mac=
wan1_heartbeat_x=
wan1_hostname=
wan1_hwaddr_x=
wan1_hwname=
wan1_ifname=eth0
wan1_ipaddr=0.0.0.0
wan1_mroute=
wan1_mtu=
wan1_nat_x=1
wan1_phytype=
wan1_ppp_echo=0
wan1_pppoe_ac=
wan1_pppoe_auth=
wan1_pppoe_ifname=
wan1_pppoe_mru=1492
wan1_pppoe_mtu=1492
wan1_pppoe_passwd=
wan1_pppoe_relay=0
wan1_pppoe_service=
wan1_primary=0
wan1_proto=dhcp
wan1_proto_t=dhcp
wan1_realip_ip=
wan1_realip_state=0
wan1_route=
wan1_s46_ealen_x=0
wan1_s46_hgw_case=0
wan1_s46_offset_x=6
wan1_s46_peer_x=
wan1_s46_prefix4_x=
wan1_s46_prefix6_x=
wan1_s46_psid_x=0
wan1_sbstate_t=3
wan1_state_t=4
wan1_unit=1
wan1_upnp_enable=1
wan1_vendorid=
wan1_vpndhcp=1
wan1_wins=
wan_auth_x=
wan_clientid=
wan_clientid_type=0
wan_desc=
wan_dhcp_qry=1
wan_dhcpenable_x=1
wan_dns1_x=1.1.1.1
wan_dns2_x=1.0.0.1
wan_dnsenable_x=0
wan_enable=1
wan_gateway=0.0.0.0
wan_heartbeat_x=
wan_hostname=
wan_hwaddr_x=
wan_hwname=
wan_ifname=eth4
wan_ipaddr=0.0.0.0
wan_mtu=
wan_nat_x=1
wan_phytype=
wan_ppp_echo=0
wan_pppoe_ac=
wan_pppoe_auth=
wan_pppoe_hostuniq=
wan_pppoe_mru=1492
wan_pppoe_mtu=1492
wan_pppoe_passwd=
wan_pppoe_relay=0
wan_pppoe_service=
wan_pppoe_username=
wan_pptp_options_x=
wan_primary=0
wan_proto=dhcp
wan_s46_ealen_x=0
wan_s46_offset_x=6
wan_s46_peer_x=
wan_s46_prefix4_x=
wan_s46_prefix6_x=
wan_s46_psid_x=0
wan_s46_psidlen_x=0
wan_unit=0
wan_upnp_enable=1
wan_vendorid=
wan_vpndhcp=1
wan_wins=
wandog_delay=0
wandog_enable=1
wandog_fb_count=4
wandog_fb_restart=0
wandog_interval=3
wandog_maxfail=5
wanports=4 0
wans_lanport=4
wans_lb_ratio=3:1
wans_mode=fb
wans_standby=1
wans_usb_bk=1
wans_usb_bk_act=0
I wish I could help, but don't have Dual WAN. Hopefully, the community can help. Maybe try a new posting asking about setting up Dual WAN using 388 firmware (broadly, not specific to this router)?
Hello there,
Asus confirmed all reported bugs.
Sometimes I see that information WAN, only QOS Speed Connection window. Message WAN disconnected "disappears" alone.
Internet connection works without any problems. And is stable.
Dear Asus,
Router is really good.
1.)
Can You add possibility filtering WWW pages on the router, router should uses Filters from AdBlock, AdGuard.
Lists are available on the GitHub, for example: https://majkiit.github.io/polish-ads-filter/
Given WWW is only example, which has explain my idea.
2.)
Add possibility set different DNS for children.
Main DNS: Google, CloudFlare, etc.
Children DNS: Secure DNS (Only Children's devices ).
Days without restart: 27 days 12 hours 10 minutes 38 seconds
I saw in log:
Aug 21 23:17:37 wlceventd: wlceventd_proc_event(503): eth6: Deauth_ind XX:XX:61:B3:6A:FF, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Aug 21 23:24:26 wlceventd: wlceventd_proc_event(539): eth6: Auth XX:XX:F6:BD:72:B1, status: Successful (0), rssi:-50
Aug 21 23:24:26 wlceventd: wlceventd_proc_event(568): eth6: Assoc XX:XX:F6:BD:72:B1, status: Successful (0), rssi:-50
Speed dropped for a minute and return to normal.
And there is difference between lists devices: Router - Access point. Device XX:XX:F6:BD:72:B1 is not show on the router.
It is laptop from which I write report... Internet works correctly.
5400
RT-AC58U V3
And step by step router increases use RAM and processors.
After restarts 5400:
Screenshot 2023-08-22 at 08-24-36 ASUS Wireless Router TUF-AX5400 - Mapa sieci.png
Momentary loss of speed. Temporarily usage CPU 90% next return to normal uses 1-8%.
The amount of free RAM decreases. Working time: 6 days 13 hours.
What issues are you seeing that you are looking for new firmware?
