bbunge
Part of the Furniture
ASUS RT-AX86U Pro Firmware version 3.0.0.4.388_24198
SUPPORTTABS_VERSION 3.0.0.4.388_24198
52.73 MB
2023/11/08
Bug Fixes and Enhancements:
- Fixed WAN connection issues.
- Fixed v6plus related issues.
- Added OCN support.
- Resolved an issue that caused hostname errors in the DDNS service.
- Resolved OpenVPN server TAP mode issue.
- Fixed the problem that the AiCloud app cannot add router on Android 9.
- Ensured consistent display of client status on the WireGuard server.
- Enhanced system stability when accessing the WireGuard server with DMZ enabled.
- Improved stability when enabling or disabling the WireGuard server.
- Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
- Corrected a bug encountered when adding a rule to the network services filter.
Security Fixes:
- Fixed several curl vulnerabilities.
- Fixed OpenSSL vulnerabilities.
- Upgraded to the latest dropbear version.
- Fixed a stack overflow vulnerability.
Please unzip the firmware file, and then verify the checksum.
SHA256: 4d84b42366d815a0d9c2a25a8a45420495e551bcaec4c7ebd23127693209f04c
www.asus.com
52.73 MB
2023/11/08
Security Fixes:
RT-AX86U Pro|WiFi Routers|ASUS Global
AX5700 Dual Band WiFi 6 Gaming Router, Mobile Game Mode, AiProtection Pro, WPA3, Parental Control, Mesh WiFi support, 2.5G Port, Gaming Port, Adaptive QoS, Port Forwarding
