ASUS RT-AX86U Pro Firmware version 9.0.0.6.102.4856
Smokey613
I ran into an issue with the Beta firmware on my AX86U Pro. I made a backup of the configuration and then tried to enable Dual WAN just to see if it worked any better.... I know... should have known, anyway the router came up but I was unable to obtain any DHCP IP address from it by wifi or LAN.
I did a reset using the button on the back and then loaded my recent backup. It all came back up with some exceptions.
I had created 2 Guest Networks with separate VLANS, one for my IoT stuff and another for Guest access.
(A note on this... I originally attempted to use their built in IoT network but discovered once created, there was no way to disable AP Isolation on that network. I needed my Ring devices to talk to each other so that was not going to work, hence I made a regular Guest Network and then I could disable AP Isolation. This worked as desired.
Anyway, after restoring a good known config, the router came back up but I discovered that while the 2 Guest networks were still there, their SSID and password information was missing. I had to put that information back in for both guest networks and then everything went back to working as before. I also had to re-assign my IoT Guest network VLAN to LAN port 4 which I had assigned it to originally.
I think Asus may be on the right track but they have more work to do.
On another note, I really like the Arista NGF. It is really easy to configure but I got a wild idea to try and simplify my network and still accomplish what I want as far as VLAN isolation.
Any improvements in Dual WAN?
Yes, now that I no longer use Asus routers …. 😁
I decided to go back to the Arista / eero solution.
FYI …. my current inventory of Asus routers:
1 - RT-AX86U Pro
2 - RT-AC86U
2 - XT8 v1
1 - RT-AC1900P ( on loan to neighbor )
1 - RT-AX86U Pro
2 - RT-AC86U
2 - XT8 v1
And with the exception of the one on loan are the rest dust collectors?
