Asus RT-AX86U Pro Performance
This is perhaps already fixed in current Asuswrt. This is why you are getting better results.
Check @Smokey613 signature weekly for updates. He doesn't run the same hardware longer than a week.
yeah I'll look forward to the new Merlin update with hopefully the fix. Mean while I'll keep wireguard off and use a docker container for that service
You can see the dip in performance whilst I resolve the problem, it's very noticeable. The big dip down to 400 MB/s was me running wireguard and using SkyNet which I've turned both off now and getting the full 1GB/s now
You can also see the more green which is where the new PRO router is more stable and giving better performance
I've got a AX88U running merlin 388.1, when WG is turned on Flow Cache is disabled & I'm also seeing almost a 50% drop in internet speed :(
What else do you use Internet for except speed test? From what I see most of your traffic must be to speed test servers.
I instantly put Merlin on my Pro but I might go back to stock for now. Some notes:
My old AX82U had about 8-10 foot more range. Usually I can just about touch the gate at the end of driveway before my phone gets knocked off the Wifi but can't with the Pro.
Now granted this is with the basic config of having all 3 antennas pointing upward as shown in the AX-86U manual but the Pro doesn't have one that I could find. I can't see why 3 vertical wouldn't still be optimal for the Pro. I may try the 45 degress angle thing as the driveway is laterally below the router. Doubt that actually does anything though.
I also doubt changing to stock will increase wireless range but worth a try.
I think you found the problem. Turned off Wireguard and flow cache is enabled again. Thoughput appears much better, will monitor today in Grafana and update with results
Currently running on the AX86U Pro with Merlin 388.1 with both runner and flow cache enabled and looking better
It's my understanding that Asus is working on changes to the firmware that will make flow cache compatible with WireGuard so at some point in the future you won't suffer from the speed penalty.
Edit: And had you mentioned WireGuard in your first post we could have immediately solved the issue. I understand though that for most people mentioning WireGuard would have not crossed their minds as something that might be involved. Moral of the story...when seeking help be generous with information when explaining your configuration.
According to the 388.2_alpha-thread flowcache is reenabled with wireguard running, and the speed drop is fixed. :) Just wait patiently for RMerlin to release it when ready.
Riviera Cable 300/30 Mbps ( Primary ) / Brightspeed fiber 100/100 ( Seconday / Plex Server )
Firewalla Gold v2 Dual WAN Failover
2 - eero Pro Bridge mode - wired mesh
Hey @Tech9 …. the eero auto update bit me again! This last one just pushed out earlier this week caused my eero Pro to become unstable. I think that eero, like every other wireless router manufacturer has sacrificed their AC products so they can sell their latest/greatest devices.
I am back to using one of my AC86U units in AP mode for wifi duties.
I'm checking your signature regularly. When is Omada coming?
Yeah sorry I wasn't aware wireguard could impact the router, I understand if I was connected and using the VPN because the router might be working to process the traffic but not when its static with no client connections
Anyway it's not a big issue right now because I use WG in a container on my Intel NUC server. It would be nice to have a clean setup and have WG on the Asus one day
Hi
Has this issue with enabling WG and flow cache been resolved now please ?
Could you elaborate on what exact issue you are inquiring about?
Based on my understanding this is the current status. I could be wrong though.
All AC routers except 86U (and one other model that escapes me right now): No hardware acceleration for both regular and WG traffic.
AC86U: Hardware acceleration for WAN traffic but not for WG traffic.
AX routers: Hardware acceleration for WAN traffic but not for WG traffic.
