OzarkEdge
Part of the Furniture
I'll play with that, I do have DoT enabled in the AX86U. I'll disable and try the Re-Add trick in the Wzye app to change the devices wireless network.
I'm not familiar with Wyze 'Re-Add trick'... I just use the Add new device setup routine.
To confirm, after setting up your Wyze Cam2 and have it connected, you were able to set the AX86U's WAN | DNS Privacy Protocol setting back to DoT?
Yes, disable DoT temporarily to permit cam setup... an easy toggle, and another Wyze nuisance.
OE
