Grimm
Yes, physically leads are there, right now theres a 86u right next to the router and connected. The other 86u which dont have any wifi connections is upstairs, it is also directly connected to the modem , so unplug it from modem and plug into router downstairs.2x AC86U in AiMesh will provide more coverage and support more devices than 1x AX86U, if that's your question. The best performance is when the two routers are wired together and not wireless. Even better performance is Router + Access Point on different Wi-Fi channels, not AiMesh.
So i use the downstairs 86u as the main router, connected to the modem.
The upstairs 86u i can remove the lead from the modem and plug it into the downstairs 86u instead
So main router downstairs connected to modem, then a lead from it already going through floorboards connected to the upstairs 86u
So both linked via a network lead, main downstairs i dont want to loose any of its named list, you know when a device is connected it might be called Amazon AS2244 and i know its a echo show 10, so renamed it, and this is the overloaded router. The upstairs one i dont care what i loose because there is only a Philips hue bridge connected now, rest have been moved to ZigBee.
So how )- ive never been brave enough to link them and change the mode in case i loose my special names.
I did print out a list, im reading 2 diffrent ways, the downstairs has a reserved ip range for example 1 to 127 and then the upstairs has the range of 128 to 255 both broadcast the same router id name on both bands.
The other was to use a diffrent ip pool, which i sort of tried, but could only connect to router 1 when router 2 switched off
Sorry the more i type the more complicated it sounds. Also im an expert in once sence, but a total beginner in another sence -)
So, downstairs router 4 ports in use, but i can ger rid of the Zigbee bridge and use the echo show 10 zigbee bridge, i have 3 of the echo show 10, so that leaves a port to run the lead to the upstairs router, lead already in place when i connected the upstairs router to the modem
ok, i just read back what i typed and its all confusing as hell, so could you tell me the mode to switch the master router to and if i need to reserve 1 to 127
Then the upstairs router, what to set that to, or will it find it via the network lead.
i think i need to re write that lot, but i think you know what im trying to do .
1, downstairs router, right next to modem, many connections, some connections coming from upstairs (will be main)
2, upstairs router, a distance from the modem, but has a very long Cat 7 lead going to it, not any wifi connections to it now, only philips hue direct
(Slave) ha ha i forgot the correct name...
I guess if i link them using AiMesh Some names would change anyway.
So be easier if you said how you would use AiMesh using cat 7 leads not via wifi
hope this makes sense, it does to me, but getting it on forum pages is a nightmare.
Thanks for any help, please understand i cant yet understand the AiMesh settings.
Pat
