Asus RT-AX88U configure Wifi6 in mixed environment
@kidd232
US/823 5Hz in the previous post (due to the maximum limit)
US/823 2.4Hz
     80, RANGE_2G_20M_1_1,     RATE_SET_2G_20M_12, /* 20.00dBm,       1, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_CDD1, VHT10-11SS1_TXBF1) */
     72, RANGE_2G_20M_1_1,     RATE_SET_2G_20M_14, /* 18.00dBm,       1, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_STBC, VHT10-11SS2) */
     96, RANGE_2G_20M_1_11,    RATE_SET_2G_20M_10, /* 24.00dBm,    1-11, (DSSS1-11_MULTI1) */
     87, RANGE_2G_20M_2_2,     RATE_SET_2G_20M_12, /* 21.75dBm,       2, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_CDD1, VHT10-11SS1_TXBF1) */
     86, RANGE_2G_20M_2_2,     RATE_SET_2G_20M_14, /* 21.50dBm,       2, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_STBC, VHT10-11SS2) */
     88, RANGE_2G_20M_3_3,     RATE_SET_2G_20M_12, /* 22.00dBm,       3, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_CDD1, VHT10-11SS1_TXBF1) */
     96, RANGE_2G_20M_3_3,     RATE_SET_2G_20M_14, /* 24.00dBm,       3, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_STBC, VHT10-11SS2) */
     88, RANGE_2G_20M_4_8,     RATE_SET_2G_20M_12, /* 22.00dBm,     4-8, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_CDD1, VHT10-11SS1_TXBF1) */
     96, RANGE_2G_20M_4_8,     RATE_SET_2G_20M_14, /* 24.00dBm,     4-8, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_STBC, VHT10-11SS2) */
     88, RANGE_2G_20M_9_9,     RATE_SET_2G_20M_12, /* 22.00dBm,       9, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_CDD1, VHT10-11SS1_TXBF1) */
     94, RANGE_2G_20M_9_9,     RATE_SET_2G_20M_14, /* 23.50dBm,       9, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_STBC, VHT10-11SS2) */
     87, RANGE_2G_20M_10_10,   RATE_SET_2G_20M_12, /* 21.75dBm,      10, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_CDD1, VHT10-11SS1_TXBF1) */
     86, RANGE_2G_20M_10_10,   RATE_SET_2G_20M_14, /* 21.50dBm,      10, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_STBC, VHT10-11SS2) */
     78, RANGE_2G_20M_11_11,   RATE_SET_2G_20M_12, /* 19.50dBm,      11, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_CDD1, VHT10-11SS1_TXBF1) */
     82, RANGE_2G_20M_11_11,   RATE_SET_2G_20M_14, /* 20.50dBm,      11, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_STBC, VHT10-11SS2) */
     62, RANGE_2G_40M_3_3,     RATE_SET_2G_40M_5, /* 15.50dBm,       3, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_TXBF1) */
     68, RANGE_2G_40M_3_3,     RATE_SET_2G_40M_21, /* 17.00dBm,       3, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_CDD1, VHT10-11SS1_STBC, VHT10-11SS2) */
     66, RANGE_2G_40M_4_4,     RATE_SET_2G_40M_5, /* 16.50dBm,       4, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_TXBF1) */
     68, RANGE_2G_40M_4_4,     RATE_SET_2G_40M_21, /* 17.00dBm,       4, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_CDD1, VHT10-11SS1_STBC, VHT10-11SS2) */
     74, RANGE_2G_40M_5_5,     RATE_SET_2G_40M_23, /* 18.50dBm,       5, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_CDD1, VHT10-11SS1_STBC, VHT10-11SS1_TXBF1, VHT10-11SS2) */
     76, RANGE_2G_40M_6_8,     RATE_SET_2G_40M_5, /* 19.00dBm,     6-8, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-11SS1_TXBF1) */
     80, RANGE_2G_40M_6_8,     RATE_SET_2G_40M_21, /* 20.00dBm,     6-8, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_CDD1, VHT10-11SS1_STBC, VHT10-11SS2) */
     76, RANGE_2G_40M_9_9,     RATE_SET_2G_40M_23, /* 19.00dBm,       9, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-9SS2, OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, MCS8-15_TXBF0, VHT10-11SS1, VHT10-11SS1_CDD1, VHT10-11SS1_STBC, VHT10-11SS1_TXBF1, VHT10-11SS2) */
this commands verify you current power
2.4Hz:
wl -i eth6 txpwr_adj_est
5Hz:
wl -i eth7 txpwr_adj_est
p.s. for 5Hz with bandwidth 160 better 44/48 channel, with 80: 149-165, for 2.4Hz with bandwidth 40 6-8ch
