Hello,
Router started to behave strange:
- wasnt accepting some Devices
- impossible to log in
- soft restart didnt helped
So i though ok, let try to add newer FW (currently Merlin 386.4) -> RT-AX88U_388.1_0
After hitting upgrade via:
Administration - Firmware Upgrade - Manual firmware update : Upload
Process went till 100% , restarted....but i was still seeing 386.4
Tried to Factory reset via UI, upgrade again via different browser, but same result
So i tried:
RT-AX88U_386.8_0
even original FW_RT_AX88U_300438820558
Also Hard Factory reset - https://www.asus.com/support/FAQ/1039074/
No success (
In System Log - General Log i See those errors:
1. Anything what else could be done or the local FLASH is faulty and need to look for different router?
2. What might caused it?
Adaptive QoS - QoS - Web History - ON? i do check what are devices connecting to, this might have some writes to storage ?!
3. Do you have suggestion to any other router from Asus with 8x LAN ports ? i had becore AC88 and moved to AX88 due to faster CPU/RAM
So i tried:
RT-AX88U_386.8_0
No success (
Dec 18 15:13:48 kernel: bcm63xx_nand ff801800.nand: program failed at bb20e00
Dec 18 15:13:48 kernel: jffs2: jffs2_flush_wbuf(): Write failed with -5
Dec 18 15:13:48 kernel: jffs2: Write of 1624 bytes at 0x00420cd8 failed. returned -5, retlen 0
Dec 18 15:13:48 kernel: jffs2: Not marking the space at 0x00420cd8 as dirty because the flash driver returned retlen zero
Dec 18 15:16:48 kernel: bcm63xx_nand ff801800.nand: program failed at bae1e00
Dec 18 15:16:48 kernel: jffs2: jffs2_flush_wbuf(): Write failed with -5
Dec 18 15:16:48 kernel: jffs2: Write of 290 bytes at 0x003e1fcc failed. returned -5, retlen 0
Dec 18 15:16:48 kernel: jffs2: Not marking the space at 0x003e1fcc as dirty because the flash driver returned retlen zero
Dec 18 15:18:48 kernel: bcm63xx_nand ff801800.nand: program failed at baa1e00
Dec 18 15:18:48 kernel: jffs2: jffs2_flush_wbuf(): Write failed with -5
Dec 18 15:18:48 kernel: jffs2: Recovery of wbuf succeeded to 00380000
Dec 18 15:18:48 kernel: jffs2: Write of 349 bytes at 0x003a1f04 failed. returned -5, retlen 0
Dec 18 15:18:48 kernel: jffs2: Not marking the space at 0x003a1f04 as dirty because the flash driver returned retlen zero
Dec 18 15:20:49 kernel: bcm63xx_nand ff801800.nand: program failed at ba60e00
Dec 18 15:20:49 kernel: jffs2: Write of 2576 bytes at 0x00360794 failed. returned -5, retlen 0
Dec 18 15:20:49 kernel: jffs2: Not marking the space at 0x00360794 as dirty because the flash driver returned retlen zero
Dec 18 15:20:49 kernel: bcm63xx_nand ff801800.nand: program failed at ba40000
Dec 18 15:20:49 kernel: jffs2: Write of 2576 bytes at 0x00340000 failed. returned -5, retlen 0
Dec 18 15:20:49 kernel: jffs2: Not marking the space at 0x00340000 as dirty because the flash driver returned retlen zero
Dec 18 15:20:49 kernel: jffs2: Error garbage collecting node at 00380000!
Dec 18 15:21:48 kernel: bcm63xx_nand ff801800.nand: program failed at ba20e00
Dec 18 15:21:48 kernel: jffs2: jffs2_flush_wbuf(): Write failed with -5
Dec 18 15:21:48 kernel: jffs2: Recovery of wbuf succeeded to 00300000
Dec 18 15:21:48 kernel: jffs2: Write of 352 bytes at 0x00320f74 failed. returned -5, retlen 0
Dec 18 15:21:48 kernel: jffs2: Not marking the space at 0x00320f74 as dirty because the flash driver returned retlen zero
Dec 18 15:22:20 acsd: eth6: selected_chspec is 0x1005 (5)
Dec 18 15:22:20 acsd: eth6: Adjusted channel spec: 0x1005 (5)
Dec 18 15:22:20 acsd: eth6: selected channel spec: 0x1005 (5)
Dec 18 15:22:20 acsd: eth6: txop channel select: Performing CSA on chspec 0x1005
Dec 18 15:23:49 kernel: bcm63xx_nand ff801800.nand: program failed at b9e0e00
Dec 18 15:23:49 kernel: jffs2: jffs2_flush_wbuf(): Write failed with -5
Dec 18 15:23:49 kernel: jffs2: Write of 2576 bytes at 0x002e0850 failed. returned -5, retlen 0
Dec 18 15:23:49 kernel: jffs2: Not marking the space at 0x002e0850 as dirty because the flash driver returned retlen zero
Dec 18 15:23:49 kernel: bcm63xx_nand ff801800.nand: program failed at b9c0000
Dec 18 15:23:49 kernel: jffs2: Write of 2576 bytes at 0x002c0050 failed. returned -5, retlen 0
Dec 18 15:23:49 kernel: jffs2: Not marking the space at 0x002c0050 as dirty because the flash driver returned retlen zero
Dec 18 15:23:49 kernel: jffs2: Error garbage collecting node at 00300000!
Dec 18 15:23:49 kernel: bcm63xx_nand ff801800.nand: program failed at b9a2e00
Dec 18 15:23:49 kernel: jffs2: Write of 956 bytes at 0x002a2d70 failed. returned -5, retlen 0
Dec 18 15:23:49 kernel: jffs2: Not marking the space at 0x002a2d70 as dirty because the flash driver returned retlen zero
Dec 18 15:25:49 kernel: bcm63xx_nand ff801800.nand: program failed at b961e00
Dec 18 15:25:49 kernel: jffs2: jffs2_flush_wbuf(): Write failed with -5
Dec 18 15:25:49 kernel: jffs2: Write of 428 bytes at 0x00261f30 failed. returned -5, retlen 0
Dec 18 15:25:49 kernel: jffs2: Not marking the space at 0x00261f30 as dirty because the flash driver returned retlen zero
Dec 18 15:27:49 kernel: bcm63xx_nand ff801800.nand: program failed at b920e00
Dec 18 15:27:49 kernel: jffs2: jffs2_flush_wbuf(): Write failed with -5
Dec 18 15:27:49 kernel: jffs2: Write of 432 bytes at 0x00220f80 failed. returned -5, retlen 0
Dec 18 15:27:49 kernel: jffs2: Not marking the space at 0x00220f80 as dirty because the flash driver returned retlen zero
