ASUS RT-AX88U Pro Asus Merlin
Willi87m
Hello everyone, I have an Asus router. I currently have it running with Open VPN with Mullvad. Since the router can also use Wireguard, I would like to switch because I can set up a multihop connection with Wireguard. Since with Mullvad you can choose an input country and an output country can. I already have Wireguard running, but I'm not sure whether these are correct for some settings. Does the kill switch also work if, for example, the entrance or the exit breaks down once? Or do you then have an IP leak or DNS leak? What does it look like with the MTU setting? Optionally, I have to enter something here. The field is empty when I upload the config to the router but I get a connection.I hope you can help me because Wireguard is completely new to me and I'm familiar with OpenVPN. But guess the connection is more secure with Wireguard and Multihop, right?
Why is your connection less secure without all of the above complications and extra payments?
An OpenVPN connection is just a simple connection. And with Wireguard it is a double connection that runs over 2x servers, which is supposed to be more secure.
