ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_21514
Version 3.0.0.6.102_21514
66.97 MB
2023/06/20
New features for ASUSWRT 5.0
-Kids' Wi-Fi: Create a separate network specifically for children, complete with scheduled controls. This is suitable for children who use multiple network devices that have enabled the randomized MAC address function and are not easily recognized.
-VPN WiFi: Create a VPN network that connects to 3rd party VPN services or with ASUS site to site -VPN(https://www.asus.com/support/FAQ/1048281/) to encrypts your internet connection and hides your IP address to protect your online activities from being tracked or monitored.
-IoT WiFi : Create an 2.4G spearate network for IoT (Internet of Things) devices.
Guest WiFi: Create a guest network with a WiFi schedule and access rights to control when and how guests can use the network.
-VLAN, allow you to segment a network into smaller, virtual sub-networks, which can be used to isolate traffic, please refer to https://www.asus.com/support/FAQ/1049415/
-Multi-services WAN, create multiple profiles on a single WAN interface. (https://rog.asus.com/au/support/FAQ/1050072)
-Port isolation and AP isolation to restrict device access to each other.
Bug Fixes and Enhancements
-NowTV profile has been added under new IPTV profiles.
-IPTV settings have been updated for better compatibility with Unifi Biz VoIP service.
-Fixed a GUI bug that occurred when adding port range rules in the Network Service Filter.
-Resolved an issue that caused hostname errors in the DDNS service.
Security Fixes
-Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
-Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
-Corrected an OpenVPN vulnerability categorized as CWE-134.
-Fixed the Hostap vulnerability CVE-2019-10064.
-Patched a command injection vulnerability to improve overall security.
-Strengthened protection against SSH brute force attacks.
Please unzip the firmware file, and then verify the checksum.
SHA256: 54ffd3850a950a516f5aada33ead264f1cc27771fbf182938bd5ecf985c2c0eb
66.97 MB
2023/06/20
Security Fixes
