ASUS RT-AX92U AiMesh loses considerable speed out to the devices
For anyone following along, one replicable bug I've found in my setup is that if I have any guest wifi enabled, the speed through the mesh nodes (all nodes are wired, testing is via wire too) gets halved. If I remove the networks and also reboot the entire mesh system, it goes back. This happens even if I create a new network that nothing knows how to connect to.
That was interesting. Thanks for sharing, will give it a test and see if that setup change will make a difference.
