Asus RT-AX92u and Intel AX200 wireless adapter
taz291819
I found an Intel AX200 wireless card for my Asus G55-VW and installed it today (with the latest Intel drivers).
It would connect to the router just fine, but not in AX mode.
To remedy this, I changed the 5Ghz-2 band to AX mode only, 160Mhz only, and the channel to 100.
After applying the changes, it only took about 60-90 seconds for my laptop to see it and connect.
Just though I'd put this out there for anyone having problems.
btw, the router is running the latest firmware as well.
So you're saying you were able to connect to the 5 GHz backhaul radio? The two-stream client connect radios do not support AX.
Correct, connected to the backhaul. If you're not using it in a AI Mesh setup, the backhaul radio shows up like normal.
The backhaul can always be unhidden too, been working fine for me in mesh mode for a couple of months this way
Via web-interface or just through SSH?
My parents are about to purchase the 2-pack for their house, and I'll have to set it up for them, that's why I'm asking.
