infinity7117
Hello,
i am running the latest asus stock firmware 3.0.0.4.374_979-gbc8961e
for my rt-n16, with a wd MyBook 2 TB connected usb drive with one ntfs partition, 500 mb swap file on the hdd, transmission bittorent installed with ipkg, running with 48 MB cache( "cache-size-mb": 48, ).
All running stable, I am pretty happy about it
But, is there any way i can improve the disk performance?
It seems generally slow.
I know cpu can be the bottleneck with all the hashing for torrent pieces, and encryption, file system overhead, etc... but how can the performance be maximized? When pre-allocating files it takes la long time and router becomes less responsive, sometimes i can't connect with telnet, timeout until file is allocated.
Would there be any difference if hdd was ext2 formatted?
Any other tips?
Thank you
Any other tips?
Thank you
