Are you having this issue? VPN wired doesn't work, but wireless does?
Link
Well, its hard to say really. For me, it seems to "connect" via wired almost everytime, but hangs. Wireless however doesn't even always "connect". I will have to test it further tonight.
I should add that I tried opening ports via "Virtual Server" (port forwarding) with no luck, and even DMZ'd my machine and had no improvement. Looking at the specs again it says PPTP and L2TP, but I don't see IPsec or pass thru anywhere. I wonder if PPTP and L2TP can be supported without supporting IPsec? To me that makes no sense, but I am no expert. I thought L2TP used IPsec as encryption or something and NOT being able to pass thru would make it useless to list those as supported.
One would think a new $130 router should be able to handle what cheap $29 routers have been doing for years.
On the other hand, it IS blazingly fast! 700-800Mbit transfers measured between Gig-E machines using 9K packets without a hiccup. (my WAN is only 9Mbit, so cant speak to that port, but solid connection and no problems this past couple weeks) and I even hooked up a AP in repeater mode without problems. On 5 Ghz radio, within same room I am getting 13-18 MB file transfers to my Macbook Pro. Getting almost 150 Mbit transfers wireless is as fast as I have ever seen in real life (not synthetic) so I can't complain. (Its just the built-in Macbook Pro adapter, I think it would be faster with a better adapter) On the 2.4 Ghz radio, I have full coverage all over the house using a cheap AP set to repeater mode. That is about 150 feet long, 2 floors, and even outdoors to the back deck. House throughput ranges from 1-4 MB/sec actual measured. Outside still getting 500KB -1.5 MB / sec.
