Hi,for tomato user give a feedback here!![]()
Or you can you the thread that I created on this site.
http://forums.smallnetbuilder.com/showthread.php?t=6810
I'm using the .102 now.
I believe the problem was I had jumbo packets enabled on my gaming machine. Turned it off and now everything is groovy.
Using .102 now, and everything appears to be working well. Will continue to monitor and report any adverse findings.
Thanks...
Here is my report to Asus
Hi i got hold of the .102 firmware and have done some testing.
1. The usb led on the router now works.
2. The dhcp works.
3. I have found that the dns/loopback disconnect seems only to apply to my ipcams they are Dlink dcs-2121 firmware 2.05. And if i turn off samba sharing on the usb drive and reboot the router, It works ! I can have dlna and ftp server on and it works. So there is something with Samba sharing from usb connected to the router that doesn`t work with my Ipcams and i have 2.
4. Other servers like my nas and off router ftp there is no problem with Samba dlna and ftp services turned on.
5. I haven`t found any other problem than with samba and the ipcams. Important !! rebooting the router after turning of samba is the key to get it to work.
/Mrcom
The following is Asus' recommendation on what would be a safe setting for the transmit power:
For the NA region, the maximum is 500mW. For the EU region, the maximum is 100mW. About 80-120 mW is generally sufficient for most networking environments. Please note that higher mW may cause a decrease in the quality of the signal.
I upgraded from 3700 v1 and range and transfer rate are much better reaches spots in basement 3700 was not able to reach . Files that took 6 minutes o transfer with 3700 2 minutes with rt66
hello you know how to enable nat open on ps3?
I have a moderate nat
From the Asus Vip support the new FW 102 received, who would like to have it
Hallo Leute
Hab vom Asus Vip support die Neue FW 102 erhalten , wer sie haben möchte www.mydrive.ch
User :rtn66u@bigmag
Pss:rtn66u
der zugang bleibt 24 Stunden offen
Here you go if you missed the firmware from Bigmag. A new link just click the zip file and you get to download.entrance is closed starting from 20 o'clock
Hi,Using .102 now, and everything appears to be working well. Will continue to monitor and report any adverse findings.
Thanks...
May I ask where the .102 f/w is located? I'd like to try it B4 trying Tomato, TIA.
Updated to .102 from .100, both have been stable so far but, i'm having weird issue with both firmwares that wasn't that before. In the Connected Clients list, its seems always refreshing but only finds the clients present at the time the router rebooted. I wanted to add another client to static HDCP and never see it on that list. i remember before would have 16-18 sometimes 20 clients, now no matter how many clients i have, always shows only the ones connected when router restarted. Also, the clients would have names listed, right now all i see refresh icon going and going. Doesnt seem to affect anything, all the clients not listed work..Anyone seem this?
Welcome To SNBForums
