I would guess it is the 'fixed' 3602 release with all world region users able to install.
For a changelog, look at the notes for the 3602 release.
http://www.asus.com/ca-en/Networking/RTN66U/HelpDesk_Download/
As far as I can see there is no change in output power (speaking for the Netherlands).Hopefully it will fix ASUS issue with transmitting power when 100%=80mW for Europe
Asus partly broke DHCP in 376_2769.
Does the stock firmware still suffer from this issue?
You'll have to try. I don't run the stock firmware.
Check the content of /etc/dnsmasq.conf, see if the maximum number of lease does show 253 (the expected value), or some other odd number.
You are right. I noticed that i can only use channels from 36 up to 48 on my router, while in fact i should be allowed to use all the way up to 64.As far as I can see there is no change in output power (speaking for the Netherlands).
I don't believe there is much intelligence behind the region specific settings.
I guess Asus sets the router to "one size" fits all for the power settings.
Also the for Europe new 5GHz channel expansion is done the cheap way, such that it suits Europe and the US (channels allowed in Europe but not in the US are left out, and channels allowed in the US but not in Europe are also left out).
Maybe the source code does shed a light on above.
Since the previous update more 5GHz channels are added, at least for Europe. As these include DFS channels, I suppose the RT-N66U does now support DFS.You are right. I noticed that i can only use channels from 36 up to 48 on my router, while in fact i should be allowed to use all the way up to 64.
Maybe it's is because RT-N66U lacks DFS/TPC?
I am not sure it has these features.
I do see these additional channels since the upgrade to stock firmware 3602 and the same inMy RT-N66U only allows me to use channels 36. 40. 44. and 48.
3657.
Your signature mentions you use a Merlin branch firmware, I do not know how that follows the stock firmware.
Well, 3657 disappeared from support.asus.com.
This is getting interesting
I current use firmware from my signature (asus stock 376.1071) and everything works perfect . I only miss “Name” field in DHCP static reservation page... What is Merlin's build based or similar with my current FW, and what Merlin build is recommend to upgrade ? I don't want to upgrade Merlin build that has wi-fi range and throughput (ethernet and Wi-Fi) worse than my current FW even if it will security fix. Anyone try this new 376.3657 asus build over 376.1071?
Welcome To SNBForums
