Some ASUS websites don't have it:
I already knew that.
I current use firmware from my signature (asus stock 376.1071) and everything works perfect . I only miss “Name” field in DHCP static reservation page... What is Merlin's build based or similar with my current FW, and what Merlin build is recommend to upgrade ? I don't want to upgrade Merlin build that has wi-fi range and throughput (ethernet and Wi-Fi) worse than my current FW even if it will security fix. Anyone try this new 376.3657 asus build over 376.1071?
Doesn't anyone here find it peculiar that this firmware (version 3.0.0.4.376.3657) doesn't have any revision history, only a caveat to do a hard reset?Strange...
What is going on with the forum?
Yesterday a message about ddos protection and no site contents, this morning site busy, a posted message that went lost and now rather slow...
A few questions:I'm having some problems with this firmware on 5ghz. Sometimes data transfer stops for a few minutes without losing connection. When this happens nothing appears on the log.
Done reset after upgrade and introduced manually all settings.
Any suggestion?
1. Portugal
2. Manual. Channel 48.
3. Not applicable
4. Not applicable
Please confirm: we talk about firmware 3.0.0.4.376.3657 now, installed in your RT-N66U, right?My network is the only one on 5 GHz... seen with WiFi analyser.
Only noticed this problem after upgrade to this firmware from 3.0.0.4.376.3602 and despite this firmware not intended for Portugal didn't have this problem.
Welcome To SNBForums
