ASUS RT-N66U Firmware version 3.0.0.4.380.8228
Hello, I am new around here. After updating my ASUS RT-N66U Firmware version to 3.0.0.4.380.8228 I lost the ability to connect to my PPTP Server (Running on the Router) from outside my network, inside my network connects just fine. Already contacted ASUS, reverted firmware to previous version (Version 3.0.0.4.380.8120) and nothing. This is driving me crazy and any help would be appreciated. Logs Below.
May 12 14:29:20 pptp[xxxx]: pppd 2.4.7 started by xxxx, uid 0
May 12 14:29:21 pptp[xxxx]: Connect: ppp10 <--> pptp (x.x.x.x)
May 12 14:29:24 pptp[xxxx]: MPPE 128-bit stateless compression enabled
May 12 14:29:27 pptp[xxxx]: Cannot determine ethernet address for proxy ARP
May 12 14:29:27 pptp[xxxx]: local IP address x.x.x.x
May 12 14:29:27 pptp[xxxx]: remote IP address x.x.x.x
May 12 14:30:13 pptp[xxxx]: pppd 2.4.7 started by xxxx, uid 0
May 12 14:30:13 pptp[xxxx]: Couldn't allocate PPP unit 10 as it is already in use
May 12 14:30:13 pptp[xxxx]: Connect: ppp11 <--> pptp (x.x.x.x)
May 12 14:30:34 pptpd[xxxx]: CTRL: EOF or bad error reading ctrl packet length.
May 12 14:30:34 pptpd[xxxx]: CTRL: couldn't read packet header (exit)
May 12 14:30:34 pptpd[xxxx]: CTRL: CTRL read failed
May 12 14:30:34 pptp[xxxx]: MPPE disabled
May 12 14:30:35 bcrelay[xxxx]: ignored ENETDOWN from sendto(), a network interface was going down?
May 12 14:30:36 bcrelay[xxxx]: ignored ENETDOWN from sendto(), a network interface was going down?
May 12 14:30:37 bcrelay[xxxx]: ignored ENETDOWN from sendto(), a network interface was going down?
May 12 14:30:37 pptp[xxxx]: Connection terminated.
May 12 14:30:37 pptp[xxxx]: Modem hangup
May 12 14:30:44 pptp[xxxx]: LCP: timeout sending Config-Requests
May 12 14:30:44 pptp[xxxx]: Connection terminated.
May 12 14:30:44 pptp[xxxx]: Modem hangup
May 12 14:30:44 pptpd[xxxx]: CTRL: EOF or bad error reading ctrl packet length.
May 12 14:30:44 pptpd[xxxx]: CTRL: couldn't read packet header (exit)
May 12 14:30:44 pptpd[xxxx]: CTRL: Fatal error reading control message in disconnect sequence
May 12 14:39:47 pptp[xxxx]: pppd 2.4.7 started by xxx, uid 0
May 12 14:39:47 pptp[xxxx]: Connect: ppp10 <--> pptp (172.56.26.146)
May 12 14:40:17 pptp[xxxx]: LCP: timeout sending Config-Requests
May 12 14:40:17 pptp[xxxx]: Connection terminated.
May 12 14:40:17 pptpd[xxxx]: CTRL: EOF or bad error reading ctrl packet length.
May 12 14:40:17 pptpd[xxxx]: CTRL: couldn't read packet header (exit)
May 12 14:40:17 pptpd[xxxx]: CTRL: CTRL read failed
May 12 14:40:17 pptp[xxxx]: Modem hangup
