Asus rt-n66u looses tcp packets from WAN USB modem (Android phone)
cuper6
Hello!
I have rt-n66u with asuswrt-Merlin 380.65_4 (not the latest 380.66_x because the bug in 380.66 with unpromted restart).
My problem at the user level: the web pages are not fully dowloaded and download progress is running all the time. At the client side it looks as: open the browser, enter url and press enter, the web page is loaded uncompletely and the download progress is running infinitely.
The problem at the system level as I found it: not all TCP packets are forwarded from WAN interface to the client.
Unfortunately the problem is floating. Sometimes all works well, sometimes web pages are not fully downloaded. Restarting browser or clearing the browser cache helps but for the limited time.
I found workaround too: if I use OpenVPN on the client connected to the external VPN server by UDP all works well everytime.
My config: all router settings are default (also I made reset to factory settings).
Dual WAN is configured in failover mode:
1 WAN: cable is not connected.
2 WAN: USB as Android phone (USB modem in HiLink mode, Yota LTE provider).
WIFI: configured two networks 2.4 and 5 GHz (the problem exists on the both networks).
Client: iPad mini with iOs 10.3.2, browser Safari (I got the same results with Chrome).
I attached three files:
1) ifconfig
2) netstat on eth3 (this is WAN connected to the USB modem) for the typical session with this problem.
3) netstat on br0 (client) for the same session.
As I see the netstat sessions on eth3 (WAN) and br0 (client) are identical except the latest packets received from WAN which are not forwarded to the br0 (and to the client).:
11:26:12.340871 IP [site].https > 192.168.8.100.64777: P 28042:29004(962) ack 1235 win 139 <nop,nop,timestamp 6742810 1311196502>
11:26:12.616456 IP [site].https > 192.168.8.100.64777: P 28042:29004(962) ack 1235 win 139 <nop,nop,timestamp 6742886 1311196504>
11:26:13.220372 IP [site].https > 192.168.8.100.64777: P 28042:29004(962) ack 1235 win 139 <nop,nop,timestamp 6743036 1311196504>
11:26:14.425767 IP [site].https > 192.168.8.100.64777: P 28042:29004(962) ack 1235 win 139 <nop,nop,timestamp 6743337 1311196504>
11:26:16.830766 IP [site].https > 192.168.8.100.64777: P 28042:29004(962) ack 1235 win 139 <nop,nop,timestamp 6743938 1311196504>
11:26:21.650332 IP [site].https > 192.168.8.100.64777: P 28042:29004(962) ack 1235 win 139 <nop,nop,timestamp 6745140 1311196504>
11:26:31.266425 IP [site].https > 192.168.8.100.64777: P 28042:29004(962) ack 1235 win 139 <nop,nop,timestamp 6747544 1311196504>
11:26:50.485336 IP [site].https > 192.168.8.100.64777: P 28042:29004(962) ack 1235 win 139 <nop,nop,timestamp 6752352 1311196504>
11:27:29.016187 IP [site].https > 192.168.8.100.64777: P 28042:29004(962) ack 1235 win 139 <nop,nop,timestamp 6761984 1311196504>
I made search in the internet and found that this problem with USB modems is old.
For example: unixforum.org/index.php?showtopic=138759
  • ifconfig.txt
  • eth3.txt
  • br0.txt
