Tutorial [SOLUTION] Asuswrt-Merlin Tor via Bridge, Device, Browser, Entry (Guard)/Middle (Non-Exit) Relay, and Device/Browser/Relay Hybrid Implementations
I've incorrectly run it - I needed to provide a 'torrc' file as an $1 input.
Anyway, now I have 2 'torrc' files (/tmp/torrc & /tmp/tor/torrc), both are the same, attaching them as well.
Asuswrt-Merlin uses /tmp/torrc by default.
Now, I've run 'service restart_tor' command, but I can't find the tor process when I run 'ps | grep tor', nor I can see any files under /tmp/tor/torrc.d/ and there is no download/upload traffic, so I would guess tor doesn't work.
Asuswrt-Merlin uses Tor (capital T) by default.
What seems to be the problem?
original files available at: https://filebin.net/94x2kajxz2yx4e5o
I've found that running Tor manually without the -quiet option helps to validate the torrc. I would also recommend reviewing the /tmp/torlog for errors.
BTW... Common issues are Nickname cannot be longer than 18 characters and ensure your DataDirectory is pointing to the correct location.
I was having issues with Option #3 - Browser option - I couldn't get the Socks5 proxy listening on port 9050. After reading thru this, looked to be a similar issue of not having the input file, and then also just missing the standard "#!/bin/sh". I needed to add two lines at the top to get it working, then the rest is the same.
# vi /jffs/scripts/torrc.postconf
#!/bin/sh
CONFIG=$1
HOSTIPADDR=$(hostname -i)
source /usr/sbin/helper.sh
if [ "$HOSTIPADDR" != "" ]; then HOSTIPADDR="${HOSTIPADDR}:"; fi
pc_insert "SocksPort 9050" "SocksPort ${HOSTIPADDR}9050" $CONFIG
#!/bin/sh
CONFIG=$1
@SoFluffy
I've updated the original post.
Thank you for the correction.
Respectfully,
Gary
Is this configuration/script files still current??
For the most part. I have it running on GT-AXE11000_3004_388.8_4 and RT-AC68U_386.14_2.
Thanks....I will post if I have any problems with the minor part ;)
#vi /jffs/scripts/init-start #!/bin/sh # Note: Tor DataDirectory requires a lot of disk space, so we symlinked to our USB 3.0 Interface Device if [ ! -d "/tmp/tor" ]; then ln -s /tmp/mnt/SanDiskSDHC/tmp/tor /tmp/tor fi
I have a /tmp/tor directory so it never uses the path to the USB storage. Can I delete the tor files and/or directories under /tmp ??
