asus with merlin cannot connect to some sites
mr wire
hello
ive just flashed my asus RTac66u with marlin 380.70
some sites dont connect
This page isn’t working
02062010.site didn’t send any data.
ERR_EMPTY_RESPONSE
any help what is going on?
thanks!
hello
ERR_EMPTY_RESPONSE
thanks!
Works for me!
yes, it pings ok, but since ive flashed it i cannot connect from my end
if i use a vpn it connects also
any setting from the firmware?
I would look at dns, or dns filtering or country blocking. Are you running any scripts? Using any safe dns? The only difference between your vpn and your wan is likely dns unless you have your client set to accept dns config disabled. Then I don't know.
Try using 138.68.48.110
If that works then it’s your DNS server. Change to 8.8.8.8 and 8.8.4.4 .
not working....
yesterday i went back with original asus and all sites worked ok
merlin issue just a couple of sites.
no scripts. all standard config.
not working....
Have you reset to defaults and hand configured back?
I'm running 280.70 on my ac66 with no problems for quite a while very strange , hope you sort it out qickly and itis a simple fix
