Asus XT8 crash
h1berto
Hi, I have a couple of XT8's and in 2 days i've had 2 crashes without touching anything on the router.
The router crashes, changes the date to May 5 and restarts ?!
Log (removed the mac addresses):
Apr 1 11:19:45 wlceventd: wlceventd_proc_event(537): eth4: ReAssoc status: Successful (0), rssi:0
Apr 1 11:26:21 wlceventd: wlceventd_proc_event(508): eth4: Disassoc , status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Apr 1 11:26:22 roamast: [EXAP]Deauth old sta in 0 0:
Apr 1 11:26:22 roamast: eth4: disconnect weak signal strength station []
Apr 1 11:26:22 roamast: eth4: remove client [] from monitor list
Apr 1 11:27:42 wlceventd: wlceventd_proc_event(527): eth6: Auth , status: Successful (0), rssi:0
Apr 1 11:27:51 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind , status: 0, reason: Unspecified reason (1), rssi:0
Apr 1 11:27:51 wlceventd: wlceventd_proc_event(527): eth6: Auth , status: Successful (0), rssi:0
May 5 06:05:13 crashlog: LOG
May 5 06:05:13 kernel: klogd started: BusyBox v1.24.1 (2021-02-13 02:03:11 CST)
May 5 06:05:13 crashlog: <4>2C:AB:33:2D:10:C1 not mesh client, can't update it's ip
May 5 06:05:13 crashlog: <4> not mesh client, can't update it's ip
May 5 06:05:13 crashlog: <6>CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
May 5 06:05:23 cfg_server: event: wl_chanspec_changed_action
May 5 06:05:23 cfg_server: current chansp(unit0) is 1001
May 5 06:05:23 cfg_server: current chansp(unit1) is d024
May 5 06:05:23 cfg_server: current chansp(unit2) is d088
May 5 06:05:23 cfg_server: dump exclchans:
May 5 06:05:23 cfg_server: old wl0_acs_excl_chans:0x100c,0x190a,0x100d,0x190b,0x100e,0x190c
May 5 06:05:23 cfg_server: new wl0_acs_excl_chans:0x100e,0x190c
May 5 06:05:23 cfg_server: old wl1_acs_excl_chans:
May 5 06:05:23 cfg_server: new wl1_acs_excl_chans:
May 5 06:05:23 cfg_server: old wl2_acs_excl_chans:
May 5 06:05:23 cfg_server: new wl2_acs_excl_chans:
May 5 06:05:23 cfg_server: wl_chanspec_changed_action: Need to restart acsd for AVBL update
May 5 06:05:23 rc_service: cfg_server 1881:notify_rc restart_acsd
May 5 06:05:23 acsd: eth4: Selecting 2g band ACS policy
May 5 06:05:24 WAN Connection: WAN was restored.
May 5 06:05:25 ntp: start NTP update
Apr 1 11:35:26 rc_service: ntp 2168:notify_rc restart_diskmon
Apr 1 11:35:26 disk_monitor: Finish
Apr 1 11:35:26 disk monitor: be idle
Apr 1 11:35:26 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Apr 1 11:35:27 ddns update: ez-ipupdate: starting...
Apr 1 11:35:27 ddns update: asus_private() interface =eth0
Apr 1 11:35:27 ddns update: g_asus_ddns_mode == 2
Apr 1 11:35:27 acsd: eth4: selected channel spec: 0x1009 (9)
Apr 1 11:35:27 acsd: eth4: Adjusted channel spec: 0x1009 (9)
Apr 1 11:35:27 acsd: eth5: Selecting 5g band ACS policy
Anyone seen this problem before?
Whenever the router reboots when it restarts the log entries will have the May 5 date. That is normal. As to your spontaneous reboots, I would do a hard reset and see if that resolves it.
Ok, wasn't aware of that.
I did a full reset yesterday, i'll monitor the next days for the behaviour.
Other question is that now i always have this log entry flooding the log:
Apr 1 23:46:32 wlceventd: wlceventd_proc_event(508): eth6: Disassoc xx:xx:xx:xx:xx, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
It's an Apple Watch...weird.
I was getting those wlceventd messages a lot too, for pretty much for every Apple device I own. I think it was something to do with HomeKit.
The only "solution" I found was to change the logging level on each XT8 from 6 to 5 via ssh.
nvram get log_level (just to verify the current level is 6)
nvram set log_level=5
nvram commit
reboot
I just started to have this problem with my XT8 that acts as the node. Just crashing like crazy. I did a hard reset and then found this post. I had similar craziness in my logs as we have a ton of Apple devices so I enabled SSH and ran these commands on each one. Hopefully one of those items will solve the crashes! It's been pretty rock solid till now so I can't complain just yet.
I probably should have mentioned that I never had any crashes, but I doubt what I posted would fix that.
