Release ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388_21739 (2022/11/28 )
rudhyruiz
Hey guys I was able to upgrade my ET12 today to 3.0.0.4.388_21739-g3068dbd. Give it a check on your routers :)
Version 3.0.0.4.388.21739
2022/11/28 46.63 MBytes
ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388.21739
1. Supported WireGuard VPN server and client.
2. Supported VPN fusion. It can easily achieve VPN connection to network devices like Smart TV, Game consoles and without installing the VPN client software.
3. Supported new devices connection notification.
4. Supported connection diagnostic on the ASUS router app.
5. Supported Instant Guard 2.0 which helps easily invite family or friends to join the VPN connection.
6. Upgraded parental control and added reward, new scheduler for flexible setting
7. Fixed HTTP response splitting vulnerability. Thanks to Efstratios Chatzoglou, University of the Aegean.
8. Fixed status page HTML vulnerability. Thanks to David Ward.
9. Fixed CVE-2018-1160. Thanks to Steven Sroba.
10. Fixed cfg_server security issue.
11. Fixed miniupnpc vulnerabilities, CVE-2015-603, CVE-2017-1000494.
12. Fixed IPSec server vulnerability, CVE-2022-40617.
13. Improved connection speed with Verizon FIOS.
14. Fixed IPTV compatibility issue with Movistar. Thanks to Sergio de Luz from RedesZone.net.
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_ET12/FW_ZENWIFI_ET12_300438821739.zip
Please unzip the firmware file first then check the MD5 code.
MD5: 67d796733538bfcc08095d67538eed26
Fixed my Galaxy Tab S8 Ultra 6ghz Mesh node connection problems.
in HK my S8 Ultra and S22 Ultra both NOT getting the 6ghz firmware yet......
other than that my dual E12 work OK so far on new firmware.. Not sure if that fix the occassionally AiMesh Node disconnect issue.
Hey guys is anyone experiencing a huge lag in the WEBUI? I also noticed in previous firmware I was able to access the WEBUI using IP, and now it redirects me automatically to asusrouter dns name.
don't see any problem on the web UI so far
Are you able to use the WEBUi by IP and it does not redirect you to asusrouter.com, cause mine is automatically doing that redirection and that is causing the lag.
It did auto forward to a domain name instead of using direct IP access. However I did not see any lag in that transition.
Asus needs to bless the XT12 with this update as well. Speeds are slower than the garbage router they gave with the service 5+ years ago
