Daylight_Invader
We recently purchased the XT8 which I have to admit I am not that impressed with based on current experiences.
Firstly there appears to be no way to leave the router in full tri-band mode when use use ethernet to pipe data from one node to the next which simply does not make sense.
Wireless performance is woeful. One minute you will get very decent throughput and then a few hours later it is just awful. At first I thought it was the fact I had two nodes, but even turning off the second node and having everything just connect to the single node does not sort out the performance issues (obviously more distant devices suffer, but that bit at least is to be expected). I don't have huge numbers of wireless networks around me so I am surprised things are this poor so quickly.
I have followed the general guidance both recommended here as well as with Asus support and that is to ensure that you do a full reset whenever updating firmware, but this does not solve the issue. For the record, I am on the new 3.0.0.4.386_25524 firmware at the moment and it seems many of you seem to like this new firmware, so again I am at a loss.
Any tips on how to address overall performance issues with the XT8? Also how much spacing should exist between the two nodes? As an FYI, when I did use wireless backhaul (or strange it calls itself fronthaul), the performance was totally pants on the second node.
